evo 9 turbo on evo 8?? need info
Old Jan 10, 2007 | 07:25 PM
  #46
evilevo2006's Avatar
ok i will try my hardest to make this clear.
now lets just use easy numbers. lets say the evo runs 20psi of boost. but it taper's down in high rpm. lets say it taper's 2 psi at redline. now the car would be at 18psi at redline. lets say this car made 300hp.
now lets say you slap the evo9 turbo onto the evo8 car. i understand it will make more hp at same boost levels. so now it is making 325hp on 20psi.
now lets say you have 2 dyno graphs. one with the 8 turbo, one with the 9 turbo.
the 8 trubo AFTER peak hp starts to drop off. so will the 9 turbo. but shouldent the 9 turbo not drop off as much or as fast? wouldent that mean it is holding 20psi of boost longer befor it begins to taper. so now your tapering to 19psi at redline. get what im saying??????????
maby im just realy off track here.
Old Jan 10, 2007 | 07:27 PM
  #47
also lets just say it can now hold 20psi at redline. wouldent that make even more power uptop?? if so i think that is what people are pushing for when they ask about how taper is. they want to run set boost longer or till redline.
Old Jan 10, 2007 | 07:33 PM
  #48
vboy425's Avatar
eveyr evo 9 i tune and log boos thave been taper down ot 16-17psi. On the other hand my 04 evo with an evo 9 turbo boost 22psi taper down to 20-19.87psi up to 7400rpm. This base off Zeitronix Widband and MAP sensor.
Old Jan 10, 2007 | 07:34 PM
  #49
Turd Squirter's Avatar
Those peak HP numbers are realistically only realized for a fraction of a second. You'd be hard pressed to even notice a 15whp increase at WOT if it's only from 6.3K RPM's to 6.8K RPM's. What you will notice however is a 15wtq/20whp increase throughout the powerband beginning at 3.2K RPM's and ending around 6.5K RPM's. Power under the curve baby!
Originally Posted by geminix3
does anyone else get the giggles every time Turd Squirter starts talking about taper?
boost taper, huh? yeah, i'd have guessed you're in the "pro-taper" camp...
i dunno, maybe it's just me.
Not getting it. Something to do with my handle but...nope...no idea.
Old Jan 11, 2007 | 02:31 AM
  #50
o.e.boost's Avatar
^thats what i want to hear...maybe my next step will be alky too since all we get here in cali is $hity 91 oct....
Old Jan 11, 2007 | 01:01 PM
  #51
what post are you talking about. you mean my post made sence to where someone understands it????????? wow. i just hope everyone else understands it. it was hard to explan it
Old Jan 11, 2007 | 07:48 PM
  #52
thatsMR2u's Avatar
The graph of an Evo 9 20g turbo on an Evo 8 that had 280in 272ex cams
and the turbo housing difference
Old Jan 13, 2007 | 11:51 AM
  #53
o.e.boost's Avatar
no i was talking about turdsquirters comment!!!...as far as the tapering issue, from my research the tapering effect is because of the design of the turbo, by increasing the boost on the turbo its past the effeciency and the only thing coming out of that turbo is hot air...so the only way to really get rid of the tapering issue is to upgrade to a different style turbo(t3/gt30/35r)...but i think this may answer your question!!!
https://www.evolutionm.net/forums/sh...highlight=avcr
Old Feb 8, 2010 | 05:17 PM
  #54
EVOlute GSR's Avatar
Anyone have dyno of both 8 and 9 turbos on a evo 8 model (non-mivec)?
Old Aug 10, 2010 | 02:07 AM
  #55
albalushi85's Avatar
Originally Posted by ak47po
Stage 2 Mitsubishi Evo 9 TME titainium-aluminide turbo & 20G upgrade new, with 10.5 Large Single Puck Turbine Housing. Rated for 450HP, plus it spools quicker!
http://www.lancershop.com/customer/p...&cat=17&page=1
Do I need to change Evo8 Engine internals before upgrading to Evo9 TME turbo?
Old Aug 10, 2010 | 07:19 AM
  #56
TeStUdO's Avatar
No
Old Aug 10, 2010 | 07:36 AM
  #57
sphinxof2006's Avatar
Get a bbk
Old Aug 10, 2010 | 07:52 AM
  #58
4RETECH's Avatar
^^^ That's what I did!
Old Sep 13, 2010 | 06:34 PM
  #59
dmcghie's Avatar
if it helps any i'm swapping out my stock 8 turbo for a 9 as well...i have an 03 with the 9.8 hotside. Last time i dyno'ed it made around 317whp/320wtq with HKS 272's, stock intercooler and basic bolt ons. Not too worried about boost taper if its gonna make more power throughout the power band. I'm also getting a bigger intercooler and 02 housing so we'll see how it feels before and after.
Old Oct 26, 2010 | 11:23 AM
  #60
Thoe99's Avatar
So does anybody have any BEFORE and AFTER charts on the power increases we can expect doing this upgrade?
tscompusa
Feb 26, 2015 05:10 PM
tscompusa
Jan 28, 2015 04:43 PM
tscompusa
Apr 14, 2013 06:48 PM
tscompusa
Sep 19, 2012 11:35 PM
whitepwr
65
Aug 16, 2010 02:31 AM
