De-Cat Pipe? Worthwhile?
Old Jan 25, 2007 | 11:44 AM
djmanley's Avatar
Smile De-Cat Pipe? Worthwhile?
Hi everyone,
I've just bought an Evo 7 and was wanting to take the CAT out of the exhaust. I've done this with previous cars but never a turbocharged one. Is this an easy worthwhile first mod?
We have the added bonus here is the Isle of Man of no MOT! Yipee! (Also no speed limit in certain areas)
Thanks,
Dave.
Old Jan 25, 2007 | 11:47 AM
thisxguy's Avatar
it will give you a few more fingers of power. but some people argue that ruining the environment isnt worth the 2-3hp gain from running a test pipe instead of a high flow cat
apexi has a super cat (called a super decatalizer or something like that)...it's supposed to be just like a test pipe but its a high flow cat
Old Jan 25, 2007 | 11:52 AM
ghoonk's Avatar
In my case, I noticed a significant difference when I switched over to a test pipe on my 1.8T Passat and on my Evo VIII MR RS. Butt dyno says car accelerates faster. If you want something REALLY noticeable, install a full 2.75" turboback (given that you're running a 9.8T turbo like mine, a 3" might be overkill).
A next worthwhile mod would be a mail-in reflash (US$52), and for that you will need a Tactrix cable (US$90). After that, enjoy!
Old Jan 25, 2007 | 11:54 AM
Smike's Avatar
Its called a test pipe. Most of us run a TBE w/o the cat. You will gain hp but also de-cork the exhaust so exit flow will be increased. Yes it is a good mod.
If CATs are illegal to remove (and only a visual inspection) here you go:
https://www.evolutionm.net/forums/sh...d.php?t=208908
Old Jan 25, 2007 | 11:58 AM
Smike's Avatar
I agree a TBE would be better (as well as a flash). However, I disagree that a 2.75 is better for the 9.8 hotside - a 3in is not overkill, its the standard. 3.5-4in may be overkill on stock type turbos though...
Old Jan 25, 2007 | 12:02 PM
djmanley's Avatar
Sorry guys what to you mean by "Test Pipe" and "TBE"?
Is this some crazy evo lingo or something? :-)
Old Jan 25, 2007 | 12:08 PM
Smike's Avatar
Sorta - its like any industry literacy/diction.
Test pipe (TP) is the replacement for the CAT in the section between the down pipe from the turbo outlet/O2 housing (DP) and the cat-back (CB).
TBE - means Turbo Back Exhaust - basically DP, TP, CB all in 3 letters... (TBE > DPTPCB - its just easier to say/type)
Old Jan 25, 2007 | 12:10 PM
Steiner's Avatar
TBE stands for Turbo Back Exhaust. So basically we're talking about an aftermarket exhaust setup from the turbo back to the tail pipe.
Old Jan 25, 2007 | 04:32 PM
djmanley's Avatar
Thanks
Ok cheers guys, that cat is getting ripped off for fun!
I'll eat dolphin safe tuna from now on, contribute to the protection of the environment in a different way.
Old Jan 25, 2007 | 04:42 PM
Jakeg97's Avatar
yes , and you will notice the power gain
Old Jan 25, 2007 | 04:43 PM
evorocks's Avatar
Where about's in the Isle of Man do you live??
Old Jan 26, 2007 | 12:21 PM
djmanley's Avatar
Isle of man
Hi,
I live in Onchan? You live here too?
Clessy
13
May 15, 2014 06:03 PM
rartist
Mid-Atlantic Region
Apr 27, 2012 10:57 PM
Brez!
Jun 19, 2011 09:19 AM
Evo8uk
Dec 31, 2008 09:49 AM
makaveli_31
Apr 3, 2004 01:26 PM
