Car won't turn off!
Old Apr 20, 2007 | 11:11 AM
  #61
BBYBruno's Avatar
These pics are me just ripping out uneeded corroded wires which caused the windshield wiper issue.
I am supposed to be missing a fuse on the left side of #15?
Old Apr 20, 2007 | 11:12 AM
  #62
str8kor's Avatar
that's by far the craziest **** i've ever heard on an evo
Old Apr 20, 2007 | 12:21 PM
  #63
BBYBruno's Avatar
So can anyone show me a wiring diagram of the immobilizer so I can disconnect it.
I also saw an option on ECUFlash for immobilizer which was set at 28, could I change those settings to disable it?
Old Apr 20, 2007 | 12:32 PM
  #64
4TUN8's Avatar
Why did you go through all that trouble to turn off the engine when you could have just bogged the car and stalled it?
Old Apr 20, 2007 | 12:35 PM
  #65
dadriva's Avatar
The answer lies in the 5th pic....
Old Apr 20, 2007 | 12:36 PM
  #66
bluebyu36's Avatar
dam them wires look like they are out of an 1982 pinto. ^i dont get it?his finger?
  #67
dadriva's Avatar
Seriously though, why don't you try some contact cleaner up in the corroded areas.
Dunno about cars but it almost always does the trick on aircraft.
Old Apr 20, 2007 | 12:38 PM
  #68
BBYBruno's Avatar
1. It's not good for the car
2. The dashlights still come on after you bog it and it's drains your battery till it's dead.
Old Apr 20, 2007 | 12:43 PM
  #69
PorkRoll's Avatar
The immobilizer is not the problem,i was having the same exact problem as you. i literally just hard wired the wires, like a member said to do, and there are no longer any problems....wipers work and the car shuts down. i still have to seal the gromit though. if the car is running without the key in it, pull fuse #13 in the engine bay...its for the hazards. the car might shut off, atleast that is how ive been dealing with the problem until now Oh yea if you need a wiring diagram go tohttp://www.NE-EVOS.net you will find one on there. Good luck
Old Apr 20, 2007 | 12:52 PM
  #70
BBYBruno's Avatar
What wires did you hard wire? Do you know the exact cause of the car not turning off?
Old Apr 20, 2007 | 01:06 PM
  #71
PorkRoll's Avatar
i hard wired all of the wires on the large harness, like 20 wires. the first one i did fixed the wipers, light green wire on the bottom of the large harness, last row. i also did the two wire on the harness right below, in the black harness green in color also if i remember correctly. im not sure which corrected the shut down problem
Old Apr 20, 2007 | 01:07 PM
  #72
BBYBruno's Avatar
Oh ok thanks.
Old Apr 20, 2007 | 01:31 PM
  #73
PorkRoll's Avatar
if you clean the terminals really well and put some dioelectric grease in the prongs it shold help correct the problem for now, but the next time it rains the corrusion is back
Old Apr 20, 2007 | 01:37 PM
  #74
BBYBruno's Avatar
I'm going to go buy some qd electronic cleaner and dioelectric grease to see if that helps any.
Old Apr 20, 2007 | 01:39 PM
  #75
yikez's Avatar
i have crazy windows as well. My drivers window will go down on it's own (seriously). If i put it up, half way through it would go down on it's own! Funny thing is it only happened twice and both of those times it was raining!
All other windows are fine. go figure
