Is this clutch chatter
Old Jun 30, 2007 | 08:03 PM
dudical26's Avatar
So I just installed an exedy twin and I hear some new noises. I am not sure if this is the clutch chatter that I have read about as it seems a bit different.
When the car is is just idling it sounds fine, then when I push the clutch in I hear a rattle. When I let the clutch out the rattle goes away. Is this chatter? Is it something else?
Thanks
Old Jun 30, 2007 | 08:11 PM
Thegame's Avatar
I do not have a twin disk, but I've heard a few of them and it's probably what you're experiencing. I wouldn't worry about it. Someone who has one will chime in eventually.
Old Jun 30, 2007 | 08:17 PM
jrsimon27's Avatar
i dont have one but a friend of mine has one and yes twin disc make chattering noises when you push in the clutch pedal noise goes away
Old Jun 30, 2007 | 08:19 PM
midwestmonster's Avatar
Welcome to the world of clutch chatter with multiple a multiple disc clutch. Perfectly normal. Just put the radio on. The sound will go away.
Old Jun 30, 2007 | 09:25 PM
dudical26's Avatar
The noise DOES NOT go away when I push the clutch in, it is the opposite. I know that noise is normal with a twin disc. However, I am not sure if what I am experiencing is normal.
Again I only hear a rattle when I push the clutch in. When the clutch is out there is no rattle. Is this normal??
Old Jun 30, 2007 | 09:31 PM
jrsimon27's Avatar
twin discs chatter as for my stock clutch when i press in the clutch pedal my throwout bearing small noise goes away when i release it becomes noticed
dont know about the twin disc all i can remember from a friends car which has it is that it chatters a lot
Old Jun 30, 2007 | 09:56 PM
chaotichoax's Avatar
this is chatter
when the clutch is pushed the plates chatter
now if you had chatter when it wasn't pushed in then that would most likely be a bad throwout bearing I believe
clutch in = chatter okay
clutch out = chatter must likely an issue
Old Jun 30, 2007 | 10:32 PM
dudical26's Avatar
Originally Posted by chaotichoax
this is chatter
Thank you, this is the informed response I was looking for.
Old Jul 1, 2007 | 01:27 PM
Evoimport6's Avatar
Sounds like chatter to me
Old Jul 1, 2007 | 02:54 PM
DanJ's Avatar
I thought clutch chatter is when you are accelerating from a stop and the car chatters (bucks). What you're are hearing is the TOB.
Old Jul 1, 2007 | 03:30 PM
clutch chatter is a noise
the car bucking is not knowing how to drive
Old Jul 1, 2007 | 03:42 PM
DanJ's Avatar
Clutch chatter occurs when the clutch cone engages and disengages the case in rapid succession.
^that's what i grabbed from a google link clutch chatter
What I meant by bucking is when you engage and the clutch basically causes the whole car to chatter as you accelerate.
Old Jul 1, 2007 | 04:26 PM
Danny23's Avatar
Sounds like a typical twin disc noise. I,m sure you also get the decel noise.
Old Jul 1, 2007 | 04:30 PM
Thegame's Avatar
EvaTheEvo
Feb 6, 2016 07:04 PM
ch1215g
Feb 8, 2011 08:28 AM
kstpeter33
Aug 16, 2009 03:34 PM
sdfontanini
Feb 8, 2008 10:41 AM
Surfer_Sandman
Lancer Troubleshooting
18
Dec 5, 2002 04:55 AM
