wtf is this noise?
Old Sep 19, 2007 | 06:45 PM
Evoluvin's Avatar
im hearing a simular noise and cant figur it out wither... its been doing it for over 3 montsh now.... but my noise is only sometimes when i hit a little bump and im in like 1st idk its wierd still cant find what it is.......
Old Sep 22, 2007 | 11:47 PM
Vigman's Avatar
Can you record it to help us?
Old Sep 23, 2007 | 01:04 AM
vishus7's Avatar
does the noise come mostly from the passenger side?
if so, i might be experiencing the same problem. To me, it sounds like an interior part is vibrating, but I can't seem to pinpoint it. It comes in the general area behind or around the glove compartment. It might be my downpipe.
It's definitely not a mechanical problem i.e. clutch, brakes, etc. Well in my case that is.
Is the noise really faint or ver noticeable? does it affect drivability at all?
Old Sep 23, 2007 | 11:37 AM
Redline-Z's Avatar
Veteran: Air Force
If it barely clears it, your engine will move on start up and taking off. I bet it is either hitting the oil pan or cross bar. I had to lower my crossbar with a BR hardware kit. Check it out and see if you see marks on your DP.
Old Sep 23, 2007 | 12:52 PM
chaz517's Avatar
yup redline is right, after checking my car on ramps 3 times i couldnt tell it was htiting the top of the oil pan, so i took it to a shop and had it up on the lift, and walla, it was hittin the damn oil pan, and the tcase actually, so i took a hammer and put a small ding in the side that was hiting the t case. and same with the oil pan. try using a torch first to heat it up and then bang on it.
it never affected driveability that i noticed, going uphill i could feel a lil vibration though, and that musta been it hitting the pan. good luck, oh and it was fairly loud, especially when my car tufrned off. if you have a turbo timer when you turn the car off go under the driver side wheel and wait for the car to turn off, that how you can tell if its the exhaust, on shut down you will def hear it rattle or clunk.
Old Sep 23, 2007 | 04:12 PM
R9's Avatar
R9
its gotta be the burrito you ate the night before
Old Sep 23, 2007 | 06:13 PM
chaz517's Avatar
only thing i like from mexico is tequila
Old Feb 26, 2012 | 06:39 PM
lhwong's Avatar
Similar situation as my evo ix rs, thank you for your sharing
Old Feb 26, 2012 | 07:31 PM
lhwong's Avatar
Hi Chaz, is it the position that cause the problem ? thx
rotterdam
Outlander Sport
16
Jan 11, 2020 12:50 PM
MitsuJDM
15
Aug 28, 2019 07:43 PM
Jerm6908
Jun 7, 2014 05:33 AM
CRONZ305
Aug 29, 2012 10:23 PM
lancer586
Lancer Troubleshooting
Apr 12, 2011 10:57 AM
