Exhaust Flange Measurements
Old Nov 5, 2007 | 01:56 PM
McDougal's Avatar
Hello,
I am trying to get a couple exhaust flanges made so that I can replace my test pipe with a HFC for emissions. I have the eBay 3" TBE exhaust. Does anyone happen to know what the dimensions of the eBay exhaust flanges is? The main thing I am looking for is the space between the center of the two bolt holes and the total length of the flange.
Any help would be appreciated!!
Old Nov 5, 2007 | 02:01 PM
meckert's Avatar
Get yourself a cheap micrometer....and crawl under the car and measure away..should be able to get a mic for a few bucks, I have a plastic one just for this kind of stuff... Just a thought its a tool you will use again and again.
Old Nov 5, 2007 | 02:14 PM
McDougal's Avatar
Where can I find one of those for "just a few bucks?" Everything I found via a google search was over $100.
Old Nov 5, 2007 | 02:15 PM
PVD04's Avatar
Harbor Freight.
Old Nov 5, 2007 | 03:02 PM
McDougal's Avatar
Originally Posted by PVD04
Harbor Freight.
I looked and didn't find anything.
Old Nov 5, 2007 | 03:43 PM
dubbleugly01's Avatar
a ruler would be fine for that measurement, no need for a micrometer. You'll have to unbolt it though.
If you have a true 3" exhaust, the flange will be pretty standard. Just tell them you need a two bolt 3" flange and it should fit fine.
Old Nov 5, 2007 | 04:14 PM
McDougal's Avatar
Well I know that is one option, I was just hoping someone might have one laying around so that I don't have to unbolt it. If I have to it wont be the end of the world though.
Old Nov 5, 2007 | 04:32 PM
looks to be 4 1/16" on my dp
Old Nov 5, 2007 | 04:56 PM
McDougal's Avatar
Thanks a lot man! That is exactly what I was hoping for. What kind of dp is that? Doesn't happen to be the eBay version is it? If not, it is at least a good starting point.
I am asking all these questions because a friend of mine works at a metal machine shop and can just cut these out with their CNC machine. He just needs specific measurements.
Thanks again!
Old Nov 5, 2007 | 05:15 PM
I don't remember which dp I bought, it's been laid up in the garage for a couple years now, but it was one of the popular brands at the time. It's a true 3". I just measured a gasket for the Greddy 80mm exhaust system, and it measures about 4 1/2" centerline to centerline of the bolt holes. These things are pretty much shelf items, they're pretty generic and won't be dependent on manufacturers. A two bolt 3" flange is going to have pretty standard measurements
Old Nov 8, 2007 | 09:34 AM
Steve_P's Avatar
RRE has stainless flanges for 3" pipe
humpevo311
Sep 28, 2015 06:38 PM
McDougal
Northwest Region
Oct 1, 2011 06:16 PM
ALLBLACK-EVO
Feb 2, 2011 08:23 PM
tlclee
24
Nov 14, 2006 05:49 PM
EvilDylan
Oct 22, 2004 02:30 PM
