CEL nub
Old Jan 23, 2008 | 01:46 AM
veilside prius's Avatar
CEL nub
besides maybe being annoying to have to see, whats the big deal with triggering CEL with HFC/testpipe?
Old Jan 23, 2008 | 02:43 AM
Jameson_IXMR's Avatar
The only issue is that if your CEL activated for some other reason, you might not know because of its permanent on status from the #2 o2 sensor.
Old Jan 23, 2008 | 04:39 PM
ic. how does the mechanical cel fix work?
Old Jan 23, 2008 | 04:42 PM
Foggy's Avatar
And adding the bung extension/spacer just takes the sensor a bit further away from the exhaust stream to prevent it from coming on? Does the #2 sensor ever get fouled & need to be cleaned?
Old Jan 23, 2008 | 04:43 PM
rcheung's Avatar
If you state does OBD2 scan inspections, you will fail immeidately.
Old Jan 23, 2008 | 04:47 PM
Psquared's Avatar
When my code was read, it was b/c the exhaust temp. exceeded the threshold. My understanding, is by moving the o2 out of the exhaust gas via the mechanical fix, the temp is less and within the preset threshold. Keeping the ecu happy, and the CEL off.
Old Jan 23, 2008 | 05:15 PM
k2boarder3187's Avatar
Mechanical cel fix for the O2 sensor is so easy and effective.
Old Jan 23, 2008 | 05:22 PM
prj.evo's Avatar
^yes its all of about 2$ (if you own a drill) and so far Ive never thrown the code. Ive had the exhaust about a year now
Old Jan 23, 2008 | 05:24 PM
gixxerman11's Avatar
^^^ same here
Old Jan 23, 2008 | 05:36 PM
did you make your own? what did you do?
Old Jan 23, 2008 | 05:42 PM
yokomo's Avatar
....yeah ditto, How do you do it?
Old Jan 23, 2008 | 06:10 PM
prj.evo's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=114931
I used 2
ron2003
Mar 31, 2011 04:08 PM
08_XXX
15
Oct 15, 2008 11:51 PM
Inprogress
Aug 4, 2008 10:52 AM
supersupra
11
Sep 12, 2006 08:08 PM
agent5568
Lancer Engine Tech
Apr 13, 2004 06:23 AM
