Question on triggered check engine light tonight
Old Feb 4, 2008 | 01:17 AM
hksevoix's Avatar
Got a little sideways in the evo tonight on black ice, lost it, spun around and couldn't save it from stalling and tried to start it up, wouldn't start after 4 tries then starts get a check engine and comes up as barometer pressure sensor, can some one explain?? Thanks
Old Feb 4, 2008 | 06:32 PM
hksevoix's Avatar
Bump
Old Feb 4, 2008 | 06:41 PM
tnhockey's Avatar
thats weird...that same thing kinda happened to me a couple months ago. i was doin donuts in the parking lot after work in the snow and i hit a dry patch and when my car came to a stop it stalled...then i tried to start it and it started after the second try. check engine light came on and it was my cam position sensor and cam timing sensor? (not sure if that second ones correct...i dont really remember) but when i started my car the next morning the light was off. try disconnecting your neg bat terminal for a few minutes...it shud go away.
Old Feb 4, 2008 | 09:21 PM
chaotichoax's Avatar
disconnect your battery and reconnect it after depressing the brake pedal for ten seconds
when you start it more likely than not the code will be gone
Old Feb 5, 2008 | 12:26 AM
hksevoix's Avatar
yeah I have a portable code scanner and removed the code with that (carry it with me since I have a habit of triggering codes lol) I'm just trying to figure out how barometer pressure would have anything to do with my mishap, I'm curious to know though why it took several tries to start the car in general, I'm wondering if it has anything to do with me beating on it before hand.. thanks for the responses guys, anymore info?
Old Feb 6, 2008 | 10:34 PM
hksevoix's Avatar
bump
Old Feb 10, 2008 | 04:21 AM
hksevoix's Avatar
bump
Old Feb 10, 2008 | 07:06 AM
BOOSTEZ's Avatar
IIRC, the barometric sensor is in the MAF. The MAF has always been sensitive so you might have jolted it to the point where it triggered that code.
Old Feb 10, 2008 | 07:09 AM
DonHugo's Avatar
^yep
has happened before- the car won;t start to "protect" itself
Old Feb 10, 2008 | 01:59 PM
hksevoix's Avatar
glad to know, thanks guys
idiaroi
Aug 15, 2015 12:03 PM
tsidrift1
Jul 28, 2015 08:57 AM
antwon6420
20
Sep 14, 2013 07:54 AM
jsmits2689
22
Apr 11, 2012 06:15 PM
Joeekrub
Dec 4, 2009 03:43 PM
