TITEK O2 Housing
Old Feb 8, 2008 | 10:08 PM
urslo4n8's Avatar
TITEK O2 Housing
Ok so i removed my exhaust manifold/turbo/o2 housing setup as one and while its out( it was removed bc i broke one of the bolts in the hotside from the manifold ) i was thinking of installing the TITEK O2 housing. Anyone have the O2housing installed? I never heard good OR bad things about it. The price seems ok. Any input?
Old Feb 8, 2008 | 10:13 PM
Steiner's Avatar
I just bought a used one. By all accounts and through my research they make a top notch o2 housing.
Old Feb 8, 2008 | 10:14 PM
urslo4n8's Avatar
Ok sweet b/c the price is not too bad either thanks
Old Feb 8, 2008 | 10:44 PM
eponti's Avatar
Titek is a good brand.
Old Feb 9, 2008 | 02:23 PM
MasterNater's Avatar
The Titek O2 housing is said to be one of the best. Quality material, excellent welds, and no boost creep issues. I was going to pick up one myself. I've had the typical boost creep issues with my eBay O2
Old Feb 9, 2008 | 06:17 PM
slow_evo's Avatar
So would this be the same for the "Helix" o2 as well? I'd imagine so seeing as how they are identically the same.
Old Feb 13, 2008 | 12:05 AM
evolness's Avatar
How do you know you have boost creep issues or not? I don't think there's much of a difference since they are made the same except for the quality of the material and welds. maybe its a leak issue..
Old Feb 13, 2008 | 12:11 AM
BigBallin's Avatar
because there is a little hole inside the o2 housing that connect the exhaust and wastegate, in the ebay one the hole is real small so to correct this you just port it. the titek comes already with a big enough opening
Old Feb 13, 2008 | 12:43 AM
evolness's Avatar
I was thinking of getting the megan o2 housing.. do you think its the same as the ebay one?
Old Feb 13, 2008 | 04:03 AM
I know this because when I'm in 4th or 5th gear and give the car full throttle the boost hits 21/22 psi and continues to climb until redline. The car never did this until I installed the eBay O2.
danielsl1999gsx
Sep 11, 2016 04:24 PM
EvoEi8ht
10
Apr 29, 2016 11:30 AM
4xforce
May 18, 2010 11:28 PM
evossl
13
Aug 19, 2008 11:22 PM
GroundHog
May 22, 2008 11:36 AM
