Problem pumping gas
Old Mar 2, 2008 | 09:11 AM
bso's Avatar
bso
Problem pumping gas
Im having a problem pumping gas with my 03 Evo. The pump will imediately click out and fuel will spill over if I repump too quick. Could a check valve or the charcoal canister gone bad? Seems like the tank is not letting out fuel vapor out.
Old Mar 2, 2008 | 06:27 PM
gsrboi80's Avatar
Common with the EVO if the pump pumps out fuel vey quickly it will stop the pump my guess is that the fuel cant get down the filler neck quick enough. Only happens at some stations
Old Mar 2, 2008 | 08:31 PM
Kilratio's Avatar
Maybe you need to insert the pump a lil deeper.
Old Mar 2, 2008 | 08:33 PM
mxpop's Avatar
Sounds like a "short nozzle" issue.......
Old Mar 2, 2008 | 08:34 PM
beomoua's Avatar
I had this same problem but only on very cold days here in MN. Let me know if you found out what's going on.
Old Mar 2, 2008 | 10:00 PM
bso's Avatar
bso
im thinking fuel vapor not escaping where it should. I did notice when I open the cap no air noise coming out of the tank.
Old Mar 2, 2008 | 10:14 PM
Drooke's Avatar
I think it also has to do with the gas station how long the nozle is
Old Mar 2, 2008 | 10:18 PM
Jameson_IXMR's Avatar
Mine does that too. You can really get that nozzle in there with a little fiddling, the deeper it is the less likely it will spray back out.
(no pun intended)
Bloomie
10
Jan 28, 2024 09:31 AM
Mycarwontstart
Jan 21, 2017 09:48 PM
Jspec EVO VIII
Jan 22, 2011 06:21 AM
dmitirygolos
10
Jan 4, 2011 11:00 PM
goBYeBYe
Sep 24, 2007 06:43 PM
