Fuel pump problems...
Old Jan 14, 2011 | 09:19 PM
Jspec EVO VIII's Avatar
So i have a Buschur Dual Walbro kit in and wanted some input on whats causing a problem before i get it checked out. My Fuel pump is "empty" only when it shows 1/2 tank left on the gauge, but when i went and pumped gas into it, it'll only take 8 gallons? Someone said it might be the arm w/the float not working correctly or is bent? Any thoughts?
Old Jan 18, 2011 | 08:20 PM
j.liu's Avatar
ttt
Old Jan 18, 2011 | 09:23 PM
EvoJoeIX's Avatar
the arm with the float is the only thing that has to do with the fuel gauge.... something is wrong there
Old Jan 21, 2011 | 07:54 AM
Jrah2987's Avatar
Veteran: Air Force
Did you put the BR kit in yourself? If so, I know how much of a pita it is to get the assembly out, so you might have damaged it on install/removal. If you had a shop do it, I would take it back and tell them to fix it asap.
Good luck.
Old Jan 21, 2011 | 11:39 AM
Bryant05TB's Avatar
This would be my guess as well.
Old Jan 21, 2011 | 12:31 PM
Someone put it in for me, i'll report back once i can get it checked out, my mechanic is out of state at the moment. So if the arm is bent, what are my options to fix it?
Old Jan 21, 2011 | 12:35 PM
EVO.C's Avatar
im running Buschur Dual Walbro kit too. but I get other issues When I fill up full tank, then start to leaking gas, dont know why and never fix.
Old Jan 21, 2011 | 12:54 PM
EvoDom's Avatar
fill the car up and see if the gauge moves. if not then the float arm could be bent. if so your going to have to take the assembly out.
Old Jan 21, 2011 | 12:58 PM
EvoJoeIX's Avatar
a gas leak isnt just something to not worry about fixing...
Old Jan 21, 2011 | 01:06 PM
goodhart's Avatar
I would guess the float arm is bent. Take it out and take a look at it.
Old Jan 21, 2011 | 02:28 PM
EVO.C's Avatar
Old Jan 22, 2011 | 12:33 AM
The gauge goes up, it just reads empty even though it isn't when it reaches about 1/2 close to 1/3 empty.
Old Jan 22, 2011 | 05:48 AM
Bobster22388's Avatar
+1 on this. It sounds a lot like the arm could have been bent when the mechanic either installed or removed the assembly.
Old Jan 22, 2011 | 06:21 AM
Roadrunr's Avatar
The float arm would have to be bent an extreme amount for this to be the problem. Your problem is the sending unit is not making electrical contact until your tank is half full. I would check the rheostat that is probably not pushed together the whole way. To the gentleman with a leak at full tank, try tightening the black electrical connector a small amount. If the nut is not tight enough the two wires will not be squeezed on the rubber seal. Do not over tighten, you could ruin the fitting.
Don
Dynotech Tuning
39
Dec 3, 2016 11:04 AM
kevin salazar
Aug 1, 2016 12:00 PM
araz5260
Aug 9, 2015 08:44 AM
duranvw
Oct 4, 2012 06:37 AM
car_nut15
Sep 16, 2011 08:49 AM
