The "Official" Evo Modding for Dummies
Old Dec 6, 2009 | 03:21 AM
  #376
fdrego's Avatar
Cheers
Old Dec 25, 2009 | 07:42 AM
  #377
supremellama's Avatar
This is always a good read.
Old Jan 9, 2010 | 01:09 PM
  #378
REV.olution's Avatar
helpful
Old Feb 3, 2010 | 11:53 AM
  #379
dasmyevo88's Avatar
WHen buying a new clutch do you feel you should buy a flywheel as well?If so what weiht what brand?
Old Feb 7, 2010 | 12:55 PM
  #380
Skott2k's Avatar
Im slowly getting my bolt on mods so i can get tuned and i just had a few quick questions. I was told for a basic tune id need LICP, Fuel Pump, TBE, MBC abd Intake. Im relatively close to that goal just need the pump and mbc but before i go for the tune should i do an 02 housing and exhaust manifold? It wasnt mentioned by my tuner or this thread (02 housing was actually) but it seems like important pieces but what do i know im in the newb thread . Ok to end the book so are the pieces necessary for a bolt on application? And will it affect my tune if i go with the basics and install these after the fact? Thanks
Old Feb 7, 2010 | 01:45 PM
  #381
EGbeater's Avatar
IMO, anything and everything that affects airflow, fuel and spark can affect the tune. A good tuner can extract a tiny bit more power or efficiency/safety out of your car by having the EXACT bolt-on configuration when he's tuning and datalogging.
So, yes - I'd install ALL the parts you're planning on having at any given "stage" of your Evo's development before you go for a tune.
Also, remember that boost level is a critical tuning factor - don't have your car tuned at a different boost level (or even a different boost controller - each one has different response characteristics on any given car) than what you'll be running later.
Old Feb 7, 2010 | 01:53 PM
  #382
EGbeater's Avatar
Depends; if the flywheel isn't damaged or warped, you can just have it resurfaced and you're good to go.
If your OEM flywheel is cooked, or if you just want to improve the acceleration of your car a little while you're in there, I highly recommend a Fidanza aluminum flywheel.
The reduced mass will mean you'll have to rev a little higher/slip it more carefully to get going in first gear, but you'll enjoy noticeably quicker acceleration (esp. in 1st and 2nd gear) due the significant reduction in rotational weight on the crankshaft. Your car will also shift better at high RPM due to the reduced load on your syncros.
OEM Evo flywheel: 13.9 lb
Fidanza aluminum flywheel (which has a steel clutch disc surface of course): 10.15 lb
Source: http://highboostforum.com/forum/show...el-for-Evo-8-9
Old Feb 8, 2010 | 05:43 PM
  #383
tmd1183's Avatar
Very helpful information! Glad I took some time to read the whole thing lol
Old Feb 11, 2010 | 04:01 PM
  #384
MR.IX.SE's Avatar
thanks for the write up
Old Feb 11, 2010 | 04:25 PM
  #385
wiley's Avatar
WOW im a new owner and deployed to iraq right now and ive been lookin for the info you provided. thanks for all the info itll help more then anyother source ive ever encountered
Old Feb 11, 2010 | 06:52 PM
  #386
chaotichoax's Avatar
any additional suggestions please post them up or pm me
Old Feb 19, 2010 | 11:14 AM
  #387
EVOlute GSR's Avatar
This is a worth while thread to read. I don't think anything is left out of this sticky.
Old Feb 19, 2010 | 12:26 PM
  #388
evolvd276's Avatar
good stuff
Old Feb 22, 2010 | 09:19 AM
  #389
Sideswipe's Avatar
Great sticky. Gave me an idea of what I want to do to an EVO when I pick one up.
Old Feb 22, 2010 | 11:52 PM
  #390
MR_Lance's Avatar
motor mounts?
