Random Mifire Code!! Please Helpp!!
Old May 26, 2008 | 06:16 PM
IEXCELR8's Avatar
Originally Posted by strtrcng426
I have couple bolt on's..where should I gap my plugs at ?? they are at .24
Are you tuned for the mods you have?
24 should be fine.
What BOV do you have and is it vta or re-circulated..
He is a thread: https://www.evolutionm.net/forums/sh...mechanical+fix
Old May 26, 2008 | 10:16 PM
erioshi's Avatar
Alot of the cars running the '03 94170008 ROM have P0300 issues especially after a cam upgrade. When a car has this issue it can be a real headache - almost impossible to get rid of. I used to keep a cReader in my glove box for my ODBII port to clear the codes because I couldn't stand driving with my CEL on constantly.
Moving to a 94170014 or 94170015 ROM can sometimes help. Another trick that worked for me was carefully reworking my injector scaling & latencies after I upgraded my injectors & moved to e85. If nothing else just buy a cReader or other OBDII scan tool online & clear the code before being tested.
Old May 26, 2008 | 10:34 PM
ChanseEvo8's Avatar
Registered User
wow sucks to hear but you should go take emission fail it and see what you need to work on lol i have problem passing my emission also which is due the end of this month check your vaccum lines and make sure your egr valve is not stuck open or closed. a code reader would be nice to see which readiness monitor is needed to be open which there is 8 of them. but good luck.....
Old May 30, 2008 | 03:55 PM
AutoXer's Avatar
Originally Posted by Chukee_R
I had p0301 for a while. Did a compression / leakdown test...leak down pointed out a valve was not seating properly. Had valves reseated, all is good now.
Doing a little research on leakdown tests and came across this thread, as well as this one: https://www.evolutionm.net/forums/sh...d.php?t=328014 . So, how did you get it fixed? Did you have to do work on the block?
XinnKoda
Lancer Troubleshooting
Apr 14, 2019 12:27 PM
GeoMitsu
Sep 20, 2016 09:36 AM
Still_Spinnin
Dec 10, 2010 06:29 AM
Z-Ball
Jul 27, 2008 03:48 PM
JDMonster
Dec 28, 2007 04:21 PM
