sluggish feel at low rpm help.
Old Jun 15, 2008 | 03:47 PM
def1's Avatar
we arent saying to launch your car every stop but its as simple as letting your clutch slip out til you get sufficient power.
Old Jun 15, 2008 | 04:06 PM
importjake00's Avatar
You don't ever drop the clutch, you just have to get the revs up. You cannot accelerate from idle rpms in the Evo.
Dropping the clutch at 3k does nothing anyway. When we do full launches, we do it at 5-6k, but that's not what we're saying. You just can feel it - you have to learn how to get the revs up and slip the clutch to get it into boost sooner. Just hitting the gas from 1k rpm will buck and sputter or bog - useless.
The clutch doesn't wear from being above 2k rpm.
very well put sir.
Old Jun 15, 2008 | 04:10 PM
dan l's Avatar
That's just poor driving. You should never be close to 800-1200rpm in the Evo when driving. Hell, I idle at 1100rpm - we have 0 power below 2000rpm and next-to-no power below 3k. It's a weak, N/A 4cyl without the turbo. I can't imagine pulling out in front of anyone with rpms in the idle range...
You don't need ANY mods for this car to be fast as hell at all times. You just have to learn how to drive it.
I really don't think an 1100 rpm idle is reasonable for most people.
The stock tune leaves a lot to be desired. Doctor up the map and you can let the clutch out at 1000rpm short shifting at 2500 and keep up with traffic just fine. You'll also notice that you can get close to 30mpg when doing this.
Old Jun 15, 2008 | 05:09 PM
Mitsu_Evo_MR's Avatar
Originally Posted by EatSleepBoost
dont drive ur evo below 2000rpm. problem solved
Totally agree!
Old Jun 15, 2008 | 05:22 PM
Warrtalon's Avatar
Sure it's reasonable. Stock is around 800 anyway, and mine is at 1k - very small difference.
You won't be going hardly anywhere short-shifting at 2500 - that means you're NEVER in boost whatsoever, and you don't get 30mph driving around in traffic - that requires long, sustained miles on the highway at optimum speeds (55-65 maybe) without ever boosting or accelerating. No matter what, none of that is relevant to the OP's perceived problem.
Old Jun 15, 2008 | 05:37 PM
5thgenluder's Avatar
thanks guys for all the advice. I have been Slipping the clutch a little when I need to accelerate quickly. I was worried that doing that would wear the clutch prematurely. Wartalon I meant slipping the clutch into gear above 2k rpm. Obviously just driving above 2k rpm would not wear the clutch. Thanks again for all your responses.
Old Jun 15, 2008 | 06:00 PM
4cdndctn's Avatar
By chance, was your A/C on at this time?
Old Jun 15, 2008 | 10:19 PM
Old Jun 16, 2008 | 07:17 AM
bbyevo8u's Avatar
you say stock idle is around 800rpms and yours is 1000rpms did you turn your idle up or are you saying that the idle vary's for different cars? my idle never changed stock vs modded "900rpms"...and if you did turn up your idle whats the benefit of doing that?!
Old Jun 16, 2008 | 07:23 AM
_Evo7_'s Avatar
^ Pushing the idle up to 1k will smooth out the idle on a cammed car in general, unless there small cams...
Old Jun 16, 2008 | 07:32 AM
EvoBroMA's Avatar
if you look at his mod list - he has cams, and a flash.
edit: short shifting before 3000 seems a little ridiculous on an Evo. try driving an old school 1.8 or 1.6L N/A VTEC honda. That'll teach you to keep the revs up. those engines are completely gutless under 3000.
Old Jun 16, 2008 | 07:47 AM
Toxin's Avatar
THE VTEC JUST KICKED IN YO'
Old Jun 17, 2008 | 11:11 AM
rEVoLed's Avatar
Originally Posted by maximZ
The Z/G have much more torque down low and coming from a Z myself I know what you mean about not having power. The issue is really you just being in too high of a gear. The Evo wants to rev and especially if you want to move out you gotta get those revs in the middle of the tach.
Like others have said, I idle at around 1k so you can't really expect any power at idle.
+1, The VQ35 and VQ family in general is nitoriouos for torque. Coming from a turboed VQ powered Nissan myself also, I understand where you coming from. The evo just require more revs off the line and you really won't feel that same torque in the low rpms like you would with a VQ so there's really nothing you can do except like what everyone said...2.3
Old Jun 17, 2008 | 11:28 AM
coffeeslug's Avatar
Originally Posted by _Evo7_
If you wanna pull out infront of a truck you need to keep the clutch dipped a bit, if u release it to early u will have no power, keep it in to long and you'l burn the clutch.
Yep, you're gonna have to use your clutch if you want to squirt into traffic.
eddy5201314
Jan 25, 2017 08:06 PM
tehSteve
Aug 7, 2012 06:31 AM
cheng_drifts
Dec 12, 2009 11:15 AM
titaniumkingpin
Nov 9, 2004 12:28 AM
93civEJ1
24
Sep 3, 2004 05:17 AM
