Whoosh sound at high rpm's?
Old Jul 7, 2008 | 09:07 AM
bbenavitz's Avatar
Wondering what you all think. I have a 2005 evo 8 with a TBE only. At full throttle when I get to 5k rpm I hear a "whoosh" sound from the engine compartment and also notice that the boost gage indicates that the boost level is backing off to about 16psi. Am I hearing the stock BOV bleed off boost? I never heard this before and the only difference is that I took off the Excede unit to go back to the stock ECM settings but I did not replace the restrictor pill. Is this somehow related? Anybody have the same experience?
Old Jul 7, 2008 | 09:44 AM
AznEvoIX's Avatar
Boost leak. Check pipes.
Old Jul 7, 2008 | 03:59 PM
el producto's Avatar
you should get a manual boost controller cuz with a TBE your boost will spike pretty high and it might be causing a boost leak...
my 05 had a boost leak on the throttle body shaft seals...
https://www.evolutionm.net/forums/sh...d.php?t=220264
Old Jul 7, 2008 | 04:10 PM
mirebih's Avatar
I have the same thing happening, and it started right after I got TBE... I thought it was normal...
seems like I was wrong...
Old Jul 7, 2008 | 04:33 PM
06MRV8Killer's Avatar
It was a srt4 flying by at teh lightspeedz lulz
No seriously it could be many things, probably boost leak somewhere
Old Jul 11, 2008 | 11:06 AM
mirebih's Avatar
so if it's boost leak, how bad can it get... I'm also loosing about 4 to 5 psi..
can i get into another problem with this... I'm going on vacation tomorrow and I will be driving the car, so I just need to make sure if it's safe to drive it for about hour and half on highway..
Old Jul 11, 2008 | 11:11 AM
GinNBoost's Avatar
It'll be safe to drive. It's just air escaping and in turn causing you to lose power.
Old Jul 11, 2008 | 11:15 AM
SLO-EVO's Avatar
if after the "whoosh sound you hear flutter, thats turbo surge.... but i recommend checking all I/C couplers for tightness
Old Aug 2, 2008 | 01:33 PM
mullen's Avatar
sounds like boost leak
Old Aug 2, 2008 | 01:38 PM
teamspink20's Avatar
sounds like what was happening to my car i didnt like how the stock uicp was looking so i ordered one from ets and problem solved and now the car runs great! so id assume boost leak
jflies
Apr 11, 2017 12:42 PM
jamrockevo8
Oct 18, 2014 02:10 PM
S2K2EVO
Jan 25, 2012 09:34 AM
Electromechanic
Mar 31, 2009 06:22 PM
NRG
34
Sep 28, 2004 10:15 PM
