How much hp is our stock bottom end good for?
Old Jul 29, 2008 | 08:27 AM
  #31
neonglh's Avatar
Originally Posted by Draven83
alot. look at STM's record setting evo. only cams and head studs.
+1 They have tons of miles on that car now, and it has gone 10.1 @ 137 on the stock block. Thats quite a bit of power
Old Jul 29, 2008 | 08:41 AM
  #32
Ev0cRaZy's Avatar
Originally Posted by PHDoc19
That's impressive! How many miles/years did you have this build?
Nevermind, you said the length of time in your post. I just don't read very well.
Went over 30k before I built a stroker
Old Jul 29, 2008 | 10:24 AM
  #33
Jeff_Jeske's Avatar
How many of you big HP guys are still using stock head bolts?
Old Jul 29, 2008 | 10:32 AM
  #34
Mellon Racing's Avatar
I'm sure there are some but head bolts are so cheap...it's like trying to make 400whp on a stock fuel pump...is it worth saving 90 bucks to risk it on a 30k car?
Old Jul 29, 2008 | 10:39 AM
  #35
neonglh's Avatar
I agree, I would do head bolts, and maybe rod bolts, at a minimum to be safe at high power. And change your fluids often!!
Old Jul 29, 2008 | 08:44 PM
  #36
hytek369's Avatar
Originally Posted by ImprezvSE
I have about 6k on mine so far and spin it to 8200 very often. No problems so far. Knock on wood!
so stock can handle frequent revs to 8000? i guess stiffer springs would be needed up top to minimize valve float
Old Jul 31, 2008 | 11:52 AM
  #37
Jeff_Jeske's Avatar
There's really no proof that the stock hardware is junk. There's really no proof that the ARPs are any better. In fact I heard there were two levels of ARPs and the cheap $99 units are the lower grade.
Old May 14, 2013 | 09:16 PM
  #38
EVO9-YOKED's Avatar
I have run 500whp/440wtrq 27 psi (HKS 3037) for 30,000 miles, 570/480 27 psi (GT3582r) for 30,000 miles and currently 550/420 24 psi (HKS TO4Z) for about 2,000 miles and i have completely stock motor with headstuds.
Old May 15, 2013 | 06:50 AM
  #39
PAZ06's Avatar
Originally Posted by Sean@Iveytune
Chelsea 612 wheel 486 tq, c16, 3yrs ago 11.0@133 stock bottom end
My DD evo 568/470 ft lb stock bottom end 3 yrs ago.........
Both stock intake, stock head. AEM engine management..........
Since then we have tuned maybe 70+ evos with stock bottom end exceeding 500 hp. Alot on flashes too.
When we started going over 500 on the stock bottom end back then it was not commonplace at all, so funny to see how common it is now.
Sean
When I get an EVO, you guys will def do the tune on it, I have heard nothing but great things about you guys
Old May 15, 2013 | 07:40 AM
  #40
AdrenalineRush's Avatar
Epic 5 year later thread bump buddy.
Not sure if you took into account your altitude when you reformatted the correction numbers cause if you didn't those numbers are quite different than what you posted.
Stripeknight
Evo X Dyno Results
Jul 20, 2015 04:44 AM
Acree
Nov 29, 2011 06:21 AM
MrEvo2nv
15
Dec 3, 2008 01:01 PM
javis06ralliart
23
Aug 24, 2007 09:04 AM
Fourdoor
27
Sep 17, 2005 07:47 AM
