Greddy Turbo timer ?
Old Aug 8, 2008 | 07:53 AM
CGroovy2k2's Avatar
Has anyone experienced their turbo timer not counting when its supposed to? Its already set with the minimum of 1min 30sec, and what used to happen was when the car is driven at high speeds the counter would count up (more time for cooling). the next day, the counter does not function like at any longer. No changes have been made to the car or the timer. Any ideas? anyone?
Old Aug 9, 2008 | 12:38 AM
19DB794's Avatar
So the TT doesnt increase the time automatically due to the driving conditions correct? The only thing I can think of is that it's not in the auto mode anyomore and it just in the mode where you select how much time you want it to run and thats it.
Old Aug 9, 2008 | 12:52 PM
djslik408's Avatar
Or was not wired correctly.
Old Aug 9, 2008 | 01:03 PM
trev0006's Avatar
mine worked like clockwork, have it looked at.
Old Aug 9, 2008 | 05:46 PM
19DB794's Avatar
If it was installed with the adapter kit its hard to mess it uo but yea double check the wiring because mine works perfectly and I installed it with the adapter.
Old Aug 9, 2008 | 09:48 PM
tonyk's Avatar
Was it turned off?
Old Aug 13, 2008 | 10:17 AM
CGroovy2k2's Avatar
Sorry haven't been able to get back with you all.
Old Aug 13, 2008 | 10:18 AM
CGroovy2k2's Avatar
Originally Posted by tonyk
Was it turned off?
Yeah when I just started it to move it out of the garage or something but then turned back on. Worked perfect before.
Old Aug 13, 2008 | 10:19 AM
CGroovy2k2's Avatar
It was installed with the harness kit and worked like a champ for a long time. Checked connections and everything is fine.
Old Aug 13, 2008 | 10:21 AM
CGroovy2k2's Avatar
I downloaded the instructions and reset the entire thing. Reset the RPM's thinking it was reading the RPM's wrong. (Did it step by step perfectly) Still nothing. Went through all the modes and still nothing.
LI_NY8
Sep 15, 2020 07:20 PM
CGroovy2k2
Dec 3, 2015 05:54 PM
gudmundur
11
Jul 19, 2008 01:21 PM
jxs1984
Aug 2, 2005 04:38 PM
gbwaacha
Oct 13, 2003 11:17 AM
