!!help!! Fuses........????
Old Sep 10, 2008 | 12:00 PM
Drooke's Avatar
so my radio started skipping my clock starting glitching and my rear windshield wiper doesn't work........but my radio finally stopped working and so did my clock im guessing its my fuses if so then where are the ones i need to replace under the hood or behind the light dimming switch....? i looked behind the light dimming switch but those aren't marked WTF someone wanna help me out
Old Sep 10, 2008 | 12:16 PM
redteam22003's Avatar
RTFM
Read The F*cking Manual
Old Sep 10, 2008 | 12:40 PM
Drooke's Avatar
Originally Posted by redteam22003
RTFM
ya ill go do that oh wait I DONT F*CKING HAVE ONE
Old Sep 10, 2008 | 04:16 PM
inslowoutfast's Avatar
The fuses behind the light dimming switch are marked. If you pull the light dimmer switch section out there is a schemtaic of the fuses labeled on the side.
Old Sep 10, 2008 | 05:01 PM
1d10t's Avatar
Id bet what ever caused the fuse to blow is connected to the glitching and skipping.
There may be a short, that caused those components to go haywire an eventually built enough amperage to pop the fuse
Old Sep 10, 2008 | 05:22 PM
Drooke's Avatar
the only thing i can think of is my meth because we took it all apart and put it back together the other night then all this crap happened
Old Sep 10, 2008 | 05:32 PM
revvin9k's Avatar
Don't know if this is a problem on the 9's, but check your drivers kick panel if the fuses wind up being good and check to see if your connectors are getting moisture in em. Use this option only if the fuses check out to be good.
EDIT: Did not see your last post about tinkering with the car the night before.
Old Sep 10, 2008 | 09:35 PM
Drooke's Avatar
alright thanks man
Cody Parrott
Lancer Troubleshooting
Jul 10, 2024 08:41 AM
elmark44
Jul 13, 2011 03:27 PM
Need4Spd
Jul 18, 2009 10:56 PM
Inflation
Apr 30, 2008 06:09 PM
t-dotlancer
Feb 25, 2006 12:07 PM
