removing clear RTV silicone...
Old Oct 10, 2008 | 12:24 PM
EvoJoeIX's Avatar
what can i use to remove clear rtv silicone off my trunk? i had it on there to keep water out of my trunk (car is wingless and used plugs +silicone to cover holes). now i have a different way to cover the holes only i cant get the old silicone off. any ideas?
i have tried rubbing alcohol, clay bar, wax, and car wash. i cannot get it off.
Old Oct 10, 2008 | 12:26 PM
DonHugo's Avatar
it should just peel off
if this is a problem, then I will have troubles when I get my wing back
Old Oct 10, 2008 | 01:00 PM
legato's Avatar
Have you tried googone? Or turtlewax's bug'n tar remover?
Try heat it up w/ a heat gun then remove it...Don't let it melt...just to where it gets softer and pliable...
BTw whats your new means to cover the hole?
Old Oct 10, 2008 | 05:14 PM
EvoJoeIX's Avatar
new means to cover holes are vinly cirlces i had cut
i thought it would peel right off to, but it adhered itself to paint. i need to find a way to get this off
Old Oct 11, 2008 | 08:36 AM
EvoJoeIX's Avatar
i got it off
i used laquer thinner. rub some of that on it and it just jumped right off the car.
i cant believe i didnt think of that earlier
i throw some pics up later of the viynl over the holes... you cant even tell they are on there unless you are right over-top of the trunk
Old Oct 11, 2008 | 11:44 AM
legato's Avatar
Sweet...Thats the secret then =)
Get some coats of wax on those areas where you applied the thinner b4 you put the vinyl stickers on.
Old Oct 11, 2008 | 05:02 PM
EvoJoeIX's Avatar
i did wax them areas to keep the paint in good shape
Old Oct 12, 2008 | 10:31 AM
hanahawaiian's Avatar
Lacquer thinner is the winner.. but careful they can strip Clear coat or base coat.. if recently painted.. make sure u put wax after u clean..
Old Oct 12, 2008 | 10:33 AM
lol i didnt read.. sorry.. Good job man!
Damian8MR
Aug 3, 2016 12:43 AM
evoniners
Jun 22, 2016 05:40 AM
Evolution Z
May 3, 2012 08:09 AM
nirvevo
Apr 21, 2010 09:57 AM
mojambo
Jun 4, 2005 07:42 AM
