Scheduled Maintenance Tables & Fluid Part #'s/Quantities
Old Mar 11, 2009 | 10:50 AM
donbrown34567's Avatar
Sweet write up man I was just about to start searching for all of this stuff, perfect timing hahah
Don
Old Mar 16, 2009 | 10:53 PM
djslik408's Avatar
good looking guys... this is good stuff!
Old Apr 15, 2009 | 06:20 PM
AIEvo9MR's Avatar
If any one would like to know its 6.3 qts for Radiator fluid.
Old May 21, 2009 | 01:51 PM
krisdlm's Avatar
where can I get oem coolant for an evo 9?
Old May 30, 2009 | 07:36 AM
mc14's Avatar
Very nice post
Old May 31, 2009 | 09:51 PM
RSGuy's Avatar
do our stock brembo's use the regular mitsubishi brake fluid pictured here?
Old Jun 4, 2009 | 05:44 AM
GiLizILL's Avatar
is this the same for the 09RA?
Old Jun 16, 2009 | 08:44 PM
KillaJay's Avatar
water pump
anyone knows when ya have to change the water pump?
Old Jun 28, 2009 | 09:18 AM
mx4life85's Avatar
I want to say 60k. But don't quote me on it.
Old Jun 28, 2009 | 12:40 PM
Blue Evo 8's Avatar
Thanks for this thread!
Old Jul 21, 2009 | 07:29 AM
icrnk's Avatar
Coolant ratio
I purchased the gallon of coolant from RussellM. What are you using as the ratio of coolant to distilled water?
I'm assuming the Mitsu Coolant is straight coolant and not pre-mixed. I believe the capacity of the radiator is 6.3 qt. (a little over 1.5 gallons). I have 1 gallon of coolant (1qt. = 0.25 gallons or there are 4 qt. to1 gallon). I was thinking of putting in 3/4 of the coolant container which would equal to about 3 quarts. The rest would be topped off with distilled water which would give me a ratio of about 48% coolant vs 63% if I used the entire gallon.
So when I do this do I first fill up the coolant reservoir with coolant and then put the rest in the radiator; topping the radiator off with the water?
Old Jul 28, 2009 | 08:23 AM
dank420's Avatar
when do you have to change your rear diff fluids?
Old Jul 29, 2009 | 07:29 AM
dank420's Avatar
bump
Old Aug 4, 2009 | 05:41 PM
yahu's Avatar
^30k. Thanks for the writeup, chaotix! Any part #'s on the belts before I dig them up on my own?
Old Aug 5, 2009 | 01:41 PM
chaotichoax's Avatar
link to timing belt kits
https://www.evolutionm.net/forums/mi...tes-belts.html
for individual belts...pm russellm
