Scheduled Maintenance Tables & Fluid Part #'s/Quantities
Old Nov 9, 2008 | 07:49 PM
chaotichoax's Avatar
OEM Fluids
5 SPEED (W5N51)
- Gear Oil API classification GL-4 SEA 75W-85 or 75W-90
- Diaqueen M/T Fluid - MZ313376 (1gal)
- capacity 2.9 qts
6 SPEED (W6MAA)
- Diaqueen Super Multi Gear 75W-85 or exact equivalent
- Diaqueen M/T Fluid - MZ313376 (1 gal)
- capacity 2.3 qts
Transfer Case
- Mitsubishi Limited Slip Differential Oil (LSD) or equivalent
- Diaqueen LSD Fluid - 3775610 (1 gal)
- capacity 0.63 qts
ACD Operating Fluid
- Diamond ATF SP III - ACH1ZC1X05 (1 qt)
- capacity 0.95 qts
Rear Differential
- capacity 0.58 qts
Mitsubishi Coolant
-MZ311986 (1 gal)
Mitsubishi Brake Fluid
-DOT 3
-MZ311987 (354 ml)
Mitsubishi Power Steering Fluid
-ACH1ZC1X04 (12 oz)
Oil Filter
-MZ690116
Timing Belt Kits - https://www.evolutionm.net/forums/mi...ce-update.html
Old Nov 12, 2008 | 09:02 PM
EVilMonkeyMR's Avatar
Nice. Anyway we can save this as a pdf file?
Old Nov 12, 2008 | 10:07 PM
importjake00's Avatar
Very helpful, thanks.
Old Nov 29, 2008 | 12:08 PM
added fluids
Old Jan 5, 2009 | 06:28 PM
dineth00i30's Avatar
awsome! now when some one go to buy a used evo they know what to check/ask the dealer.
Old Feb 10, 2009 | 11:31 PM
djslik408's Avatar
Is it possible to know the list of websites where we can order these fluids/oil?
Old Feb 11, 2009 | 02:15 AM
D-Mon3y69's Avatar
Man why did you have to put this up? Now i know everything i missed 5k ago and now i have to go do it thanks for the right up
Old Feb 12, 2009 | 01:19 PM
mitsubishiparts.net or PM russellm
Old Feb 14, 2009 | 11:21 PM
jebjkey's Avatar
good stuff here.
Old Feb 14, 2009 | 11:24 PM
Q8_EVO's Avatar
thanks man
Old Feb 26, 2009 | 02:09 PM
Skott2k's Avatar
Questions about oil, book says 10w30 but i hear different people use 5w30 also which is better? and If i use a different oil..say amsoil instead of the mobil 1 it says to use will the world keep turning? also i need 5 quarts right?
Old Mar 1, 2009 | 07:09 PM
Spinitch's Avatar
Great thread
Old Mar 4, 2009 | 01:30 PM
Ayrton Senna's Avatar
Thank you!
Old Mar 5, 2009 | 08:38 PM
I personally use amsoil 10x30 and I would definitely recommend it to anyone
technically you need 4.5-4.8 qts...if you run the larger oil filter you can add the full 5 and be right at the full line
Old Mar 10, 2009 | 05:55 PM
mr06's Avatar
Thanks
thanks a bunch for this, you saved me alot of time researching what trans, diff and acd fluids I needed and where I could get them. Went to mitsubishiparts.net and they had everything in stock.
