gauge pod install question
Old Dec 14, 2008 | 07:58 AM
AndyBandy's Avatar
Originally Posted by Tnnrx7
"TECH TIP: This pod will completely replace the stock drivers side A-pillar. Includes new mounting hardware."
Sooo...?
Sorry, i was gone most of the day yesterday.
Lancershop's piece is terrible.
Issue #1: The gauge holes arent even all at the same angle, the lower one is pitched upward.
Issue #2: I ordered the tweeter cutout version and they sent me the one without the cutout and then never responded to my calls to their answering service.
Issue #3: i had to trim a TON of material off of the bottom just to get it to fit over the existing a-pillar, which someone noted, that they said was replaced by their unit.
All in all, i should have done a negative writeup on it, but i got it installed and saw how many others left negative feedback already, so i didnt bother. Only problem is that if i ever want to remove it, i'll need to find an a-pillar because mine is royally messed up from trying to get it to fit.
Old Dec 14, 2008 | 09:08 AM
shawn360h's Avatar
so is the auto meter also one that goes overtop of the exsisting a pillar or is it a direct replacement? If it is a direct replacement im gonna see if i can exchange it for that if not i will make the one i already have work.
Old Dec 14, 2008 | 09:41 AM
Kracka's Avatar
The Autometer goes over the stock pillar.
Old Dec 14, 2008 | 02:29 PM
AndyBandy's Avatar
i would suggest trying to make the one you have work...i can't speak for the autometer piece, but its got to be better than the lancershop piece. But, with some work, the lancer shop one will fit and hold in place.
Old Dec 14, 2008 | 03:11 PM
shawn360h's Avatar
yea i already started to trim it but when i lay it over the OEM piece the bends aren't the same. Do you kno if i heat it up and put some c clamps on it to hold it down it will start to take the shape?
Old Jan 4, 2009 | 04:22 PM
luckybull's Avatar
im having the same issue. i ordered one, and it doesnt fit for ****, and im reluctant to drill into my car just to get it to fit.
spoke with someone else and they said these ones are a DIRECT replacement, as in use stock moutning tabs etc. -http://www.gaugepods.com/mitsubishi.html
im going to call them tomorrow and see if this is the case. if so im sending this pile of **** one back.
Old Jan 4, 2009 | 04:34 PM
BrandNew's Avatar
lancershop doesnt have a phone. So if you have a problem with them, it suxs to tryand get it fixed
Old Jan 4, 2009 | 07:54 PM
felickz's Avatar
GaugePods.com pic...
bzzbee2
Jun 9, 2011 12:23 PM
bboy_RES
Jan 23, 2008 06:28 PM
RedAustinIX
Mar 11, 2007 01:47 PM
Tsurara
Jun 13, 2005 06:13 AM
LancerShop.com
24
Mar 30, 2004 09:41 AM
