SRS Light Help- Front Impact Sensor!!!
Old Jan 28, 2009 | 05:26 PM
mayday3k's Avatar
well I searched and came across nothing, but my question is about 3 weeks ago I had noticed that my SRS light was on. I had a friend of mine scan it, and it said "Front Impact Sensor," he then resetted it and it was off up until today. As far as I know the car has not been in any accident. What would cause this light to trigger on and off? I can't imagine it being serious due to the fact that as soon as resetting it, it would have came back on. When it had come on I priced out a new sensor from Mitsubishi at $112.00. Have you guys/girls had this problem in the past??? Thanks in advance...
Kevin
Old Jan 28, 2009 | 06:08 PM
evokid511's Avatar
man i hope you find out the answer cuz mines doing the same thing and i cant figure ut out either it really sucks
Old Jan 28, 2009 | 06:13 PM
mayday3k's Avatar
yea i talked to my buddy and he possibly said that the connections could be courroted, so im going to check that before i spend over $100.00, but does anyone know where this is EXACTLY located???
Old Jan 28, 2009 | 06:29 PM
Mr. PSSsSt's Avatar
FCOTM Winner
yah i been having the same problems since i stalled my car about 3 weeks ago
Old Jan 28, 2009 | 08:53 PM
detroit pistins's Avatar
we just recently got a lot of rain in raleigh, and my srs light came on as well, check out this thread, it talks about the corroded connectors.
https://www.evolutionm.net/forums/in...lins-rain.html
I checked my connectors and no corrosion seems to be found.
goodluck and keep us posted of what u end up doing.
Old Jan 28, 2009 | 09:12 PM
mayday3k's Avatar
yea ill check those wires tommrow... ill let you know what i end up doing...
Old Jan 29, 2009 | 10:00 PM
waynea's Avatar
I believe there are two sensors located on the frame one on each side of the radiator. Did the computer say which sensor, left or right? It is almost certainly a bad connection, but I suppose it could be a bad sensor. If yours friends computer can tell left versus right when the SRS light is on, you might try swapping sensors to determine if it is sensor or connector. BTW which computer does your friend have a MUT II or somethings else. Thanks.
Old Jan 30, 2009 | 10:36 AM
binarysleep's Avatar
Yep, those are the sensors. They have yellow plugs. Each side is routed separately through the inner fenders. If you determine that the left side sensor is triggering the light, then you probably do have a water leak as described in the "gremlins post."
Old Feb 5, 2009 | 07:13 AM
mayday3k's Avatar
UPDATED: took it into mitsubishi... the wires are fine... and i went there to get a print out of all the service work, and foud out that the gentleman who had the car before my buddy stated the car was in a front end accident right where the sensor is... so the airbag never went off, so im gettin a new sensor installed... ill keep u all posted... thanks again
Old Feb 5, 2009 | 07:17 AM
is warranty covering it?
Old Feb 5, 2009 | 07:46 AM
mayday3k's Avatar
no it's outta warranty
Old Feb 5, 2009 | 07:59 AM
EVO196's Avatar
Wow, my SRS light came on yesterday? I'm clueless too, I thought maybe the NE cold has the sensor bugging out....
Old Feb 5, 2009 | 08:30 AM
i think my car has been in a small front hit, do u guys think this will effect my warranty?
Old Mar 13, 2015 | 09:39 AM
patric78's Avatar
Hi, in the past I had issues with the "Electrical Gremlins" (see https://www.evolutionm.net/forums/ev...s-how-fix.html) which I could fix cleaning all the connectors and better sealing the grommets.
Now I also have the SRS light coming up and the MUT II says left and right impact sensor. Before changing them (I got them quoted, in Switzerland, for about 700 US$) I will try to clean the connectors to the sensors themselves. I'll post here the result.
Old Mar 13, 2015 | 10:44 PM
lcwjr's Avatar
Seems a bit expensive. In the US, the sensors are about $120.00 each. Keep in mind that the SRS code will have to be reset at the dealership, and the cost is also about $120.00. Its difficult to imagine what would trigger both sensors except a collision, or turning the key on with both sensors disconnected. I have several previous posts about these sensors if you care to search my posts on this forum. Good luck.
Royal Evo
Mar 17, 2016 11:57 AM
raasfaas
12
Mar 14, 2009 04:12 PM
EvO03
Northwest Region
18
Nov 13, 2008 08:12 PM
projekt_shocker
Nov 18, 2007 08:48 PM
rcheung
May 29, 2005 10:16 AM
