Headlights Randomly Don't Work?
Old Mar 11, 2009 | 07:46 PM
kyoo's Avatar
Have any of you come across this before? I am running an HID kit, but I have been for the past 2 years. The headlights randomly won't come on. I say randomly because it has done this once before, and then after the car had sat for a while and I just tried turning the lights back on they worked. I had thought it would have something to do with the HID's but both of them don't turn on at the same time.
Any suggestions?
Old Mar 11, 2009 | 09:39 PM
kyoo's Avatar
bump..
Old Mar 12, 2009 | 12:22 AM
sonicnofadz's Avatar
Which HID kit did you purchase? Where did you purchase it? What bulbs are you using? If you answer any of these questions with Ebay, then you know where you went wrong. Otherwise, check your connections, and make sure excess moisture is not making it to the bulbs or ballasts.
Old Mar 12, 2009 | 06:29 AM
2.0Ldoom's Avatar
I bet the ballasts are crap, as stated above ebay HIDs are a gamble at best.
Old Mar 12, 2009 | 07:05 AM
kyoo's Avatar
IIKDO, from a vendor on the site. I thought maybe ballasts but both when out at the same time.. what are the common connections I should be checking?
Have had them with no problems for about a year and a half - I just don't get why both wouldn't work at the same time unless it was some sort of connection issue
Old Mar 12, 2009 | 07:19 AM
J8dailo's Avatar
i say it could be the headlight switch...i worked on some toyotas which the headlight randomly wont come on sometimes..
Old Mar 12, 2009 | 07:24 AM
JJsEvo8's Avatar
Check fuses as well..
Old Mar 12, 2009 | 07:25 AM
kyoo's Avatar
Could it be fuses if all of the other electrical components in the car are working?
lol where is the headlight switch? I'm really not good with electrical things
.DoT.
Oct 13, 2016 09:42 AM
Evoracing47
Sep 21, 2014 06:49 PM
Mochiman
Lancer Troubleshooting
Dec 19, 2010 08:01 PM
yorT
Oct 19, 2010 06:57 PM
Steiner
Jul 23, 2010 11:29 PM
