squeaking/chirping noise heard while driving?
Old Jun 13, 2009 | 06:30 AM
TommiM's Avatar
While driving I can hear what sounds like a rotational noise, like a squeaking, as best as I can put it. It doesnt seem to come from one wheel, but rather undereneath the car somewhere so far as I can tell. It comes on at speeds above 15mph, below 15 mph its quiet. Doesnt matter if Im in gear or in neutral, but always starts up at 15 mph++. As Im going faster the noise gets a little louder, but mostly faster/more repetitive. Any ideas? Thanks.
Old Jun 13, 2009 | 12:57 PM
ProjectMayhem's Avatar
It's coming from underneath the car? Things I can think of right off to check would be the drive shaft, make sure the breaks aren't rubbing, check the axles. It also couldn't hurt to take a look under your hood and make sure it's not a belt.
Old Jun 13, 2009 | 04:08 PM
TommiM's Avatar
I drove it somewhere to try and isolate the noise. It now actually seems like it might be a wheel bearing, possibly left front. kind of hard to isolate the noise when Im driving. If I had to descirbe the nosie better, I would say it most sounds like a bearing squeaking? I inspected suspension components, belts and tensioners thoroughly. I didnt really examine the drive shaft or test the wheel bearings? Anyway to test if its the wheel bearings without taking off the rotors and calipers?
Old May 13, 2010 | 11:17 PM
EViTZO's Avatar
I'm feel like we have the same squeaking noise from the driver-side wheel area... Mine stops if I apply the breaks a little bit but not enough to slow down the car so I think it might be the wheels rubbing on the brake calipers since my rims only have like 1mm of clearance. Do you have aftermarket rims?
David2392
Apr 25, 2016 06:58 AM
kyoo
Apr 20, 2010 02:42 PM
itsthecaptain
Lancer Troubleshooting
May 27, 2009 03:33 PM
ToMuchBoost
10
Sep 18, 2007 10:22 AM
shbomb8188
Sep 26, 2006 05:13 AM
