steering wheel
Old Sep 14, 2009 | 01:55 AM
Projekt Lancer's Avatar
steering wheel
does anyone know the bolt pattern for the evo 7 steering wheel? (jdm, the momo one with blue stitching) i imagine that its the same with the evo 8 but if anyone can clarify.. that'd be wonderful thanks.
Old Sep 14, 2009 | 09:12 AM
alexisrc's Avatar
I own one of them. I installed it on my evo 8. Same bolt pattern, no mods needed.
Old Sep 15, 2009 | 07:37 AM
o yea.. i assumed that they were the same as the evo viii...... but i have a 2010 ralliart and i would like to install this steering wheel onto it... (the stock one totally blows) and it's the same one and setup from the evo x..... so basically i need to know what type of hub i'm going to need.. or what modifactions will have to be done...
someone on this forum already informed me that they make evo x steering wheel hubs... which can easily fit my ralliart... i just need to know if my evo vii steering wheel will fit the hub itself...
Old Sep 15, 2009 | 07:45 AM
Evoardo IX's Avatar
bad idea, the evo 7 wheel is not like non airbag momo wheels which are flat and need a hub to fit, the evo7 wheel actually has a body if you know what I mean, so you can't fit a hub with that wheel. Then you have the airbag issue, I don't know if the plug from the RA is the same as the evo7 wheel. Your best bet if you dislike the RA wheel so much would be to get an EvoX wheel.
Old Sep 15, 2009 | 08:42 AM
lol... we have the same wheel
Old Sep 15, 2009 | 08:45 AM
surely there is a way though... i recall some base 03 lancers replacing the steering wheel with evo vii or evo viii wheels.. and it was not a direct bolt on..
Old Sep 15, 2009 | 10:36 AM
Evoardo IX's Avatar
'03 lancers I'm pretty sure it is a direct bolt on, the newer ralliart is a totally different car, including steering wheel column. Of course there must be a way to install it in your car but I doubt it will go on easily, and like I said before the airbag is an issue also.
Old Sep 15, 2009 | 01:09 PM
i get ya... well thx for the response.... i'll try to research this more... thx
Old Sep 18, 2009 | 03:27 AM
i wonder if the steering column would be able to fit.....
ZanarkO
Jun 14, 2014 05:29 AM
AznSupraTT
Apr 6, 2014 08:24 PM
Mr. Move
Jan 11, 2013 01:03 PM
maximusnz
May 23, 2012 06:15 PM
sum0325
10
Aug 18, 2010 10:58 PM
