Battery Replacement.. opinions OEM style
Old Jan 22, 2010 | 07:39 AM
  #46
migs647's Avatar
I can speak from experience going from interstate to yellow top.
What do you want to know?
Old Jan 22, 2010 | 08:17 AM
  #47
bLk-Ev0-aTe's Avatar
i have yellowtop, i like it
Old Jan 22, 2010 | 10:17 AM
  #48
Kevin.'s Avatar
Yellow top is going to be the best battery replacement.
Old Jan 22, 2010 | 10:24 AM
  #49
4RETECH's Avatar
Originally Posted by ekim1
Were the 35's terminals in the correct orientation or did you have to flip it around?
The 35 was the correct battery. DO Not get an 35-75 or 35R. those terminals are reversed.
Old Jan 22, 2010 | 11:07 AM
  #50
X91EVO's Avatar
Registered User
Originally Posted by 4RETECH
I did think about a mini battery, but I have seen too many go bad up here in the cold. Most of our race cars have them and they only last about 2 years.
Maybe in the future though.
exactly why I;m never buying one.. trunk mount ftw
Old Jan 26, 2010 | 02:27 PM
  #51
SpooksEvo's Avatar
I have an amp pushing a 10" sub. Which battery do you like the best
Old Jan 26, 2010 | 02:58 PM
  #52
migs647's Avatar
Is it JUST the sub? Do you ever happen to run the battery low / dead? If you ever kill your battery from playing music, go with the yellow top 100%. If you are barely pushing any wattage, then a red top should be fine. I found my interstate to be garbage after playing music on it for any period of time with the car being off. It would crank over a lot slower. I was running 600 watt system ... 10" sub and 6 speakers off of the amp.
Old Jan 26, 2010 | 06:42 PM
  #53
paintballer419's Avatar
If you do change your mind and want a small battery, back in my 240 days, I used a miata battery since it was the only oem style batter that would fit after my sr swap. It worked very well.
Old Jan 27, 2010 | 07:18 AM
  #54
EvoPooPoo's Avatar
I actually replaced my stocker with Optima red top this winter.
My car only has 58k miles... but wasn't able to turn the car over when it was -5 windchill.
Redtop = no problem thus far. It's -3 windchill today... started fine.
CCA is what you want to look at if you live in a cold region.
Old Jan 27, 2010 | 11:37 AM
  #55
dan628's Avatar
I don't know why everyone thinks Optima is so great, I use to use them, but never had good luck. Now I run Kinetik racing battery and its so much better, I run 1000 watt amp and no dimming whatsoever. I already posted my suggestion a few posts earlier, but nobody seemed interested.
Old Jan 27, 2010 | 01:33 PM
  #56
Kevin.'s Avatar
The majority speaks for the quality of a product.
Old Jan 27, 2010 | 03:32 PM
  #57
I have a yellow top, didnt run into any problems yet.
Whats the difference between a red and yellow ?
Old Jan 27, 2010 | 03:35 PM
  #58
migs647's Avatar
Yellow top is a deep cycle battery. Meaning it can take more abuse than the red top. It can be drained many times and still be recharged. The red top has more cranking amps.
Old Jan 29, 2010 | 10:21 PM
  #59
SpooksEvo's Avatar
Thanks guys, I will look into both. I had a kinetik before on my 2 G and is was pretty BA. I appreciate the opinions
Old Jan 29, 2010 | 11:45 PM
  #60
wntanEVO's Avatar
FYI, Optima ret top, from what I remember, is a pound or two lighter than the original battery. I ended up using the Interstate Megatron Plus, MTP-35, which is actually a few pounds heavier than the original. I went with the Interstate because, here in Hawaii, it is always hot, and the Megatron Plus built to withstand high heat (MTP II is better, but they don't make it in our size and/or required dimensions). I also wasn't too sure if the Optima would fit, based on the online dimensions and my own tray measurements. Instead of ordering the Optima and having it not fit, I went with the Interstate. So far, I have completely drained the Interstate battery once (3 times on the original), but have been able to recharge it by jumping it and condition it with the Battery Minder. Now that I know the Red Top will fit, I will most likely try that or look at a Kinetik(previously mentioned). Once I move to a much colder area (soon), we will see how the Interstate holds up.
