Battery Replacement.. opinions OEM style
Old Feb 3, 2010 | 08:31 PM
  #76
kblock4life's Avatar
ya optima red tops are deff. worth the money and basiclly never go bad oh maciek82 that looks soo clean in the trunk!!!
Old Feb 3, 2010 | 08:40 PM
  #77
franc01's Avatar
To those of you using the Miata battery, did you use the stock tray and holding hardware? Does anyone have a pic of a Miata battery installed? I'd like to see what sort of clearance I'd end up with.
Thanks!
-Franc
Old Feb 3, 2010 | 09:26 PM
  #78
Mike.p's Avatar
Originally Posted by xmaciek82x
I just bought a 75/35 and install was pretty simple. But then again I relocated it to the trunk
what base are you using to hold the batt down?? also where did you ground it?
Old Feb 4, 2010 | 12:12 PM
  #79
xmaciek82x's Avatar
It is a CNCed aluminm one. You can buy them on ebay.
I will post pics later of the ground location but I think it might be a poor location. I will probably redo it.
Old Feb 4, 2010 | 08:26 PM
  #80
Wat00756's Avatar
red top ftw never had a problem in my dsm
Old Mar 20, 2010 | 12:16 AM
  #81
Evolicious8's Avatar
Any one have pics of their Optima red top 35 installed?
Old Mar 20, 2010 | 05:02 AM
  #82
4RETECH's Avatar
As you requested. Sorry the engine bay is dirty.
As you can see I have to still cut the hold down bolts or just get new ones.
Old Jun 14, 2010 | 10:47 PM
  #83
codgi's Avatar
^^ Sorry to bring this one back from the dead, but I bought the 35 as well and the positive terminal would not lie flat (just as the above). Any other pics of the 35 installed?
Old Jun 15, 2010 | 07:38 AM
  #84
GaBe511's Avatar
I just installed mine and will post up pics when i get a chance. Just remember to get a height adjuster for the battery. This raises it a bit so you dont have to bolt the battery tie down as far. My battery didn't come with the height adapter but i called optima and they shipped me one for free.
Also, to fix the terminal problem, i might just dremel a notch in the back so it lays flush.
Old Jun 15, 2010 | 08:01 AM
  #85
GaBe511's Avatar
This is the height adapter before i put it on
After its installed on bottom
And finally it in the car
Old Jun 15, 2010 | 06:16 PM
  #86
BIGJEFF's Avatar
I have the blue top optima in my show truck it's a deep cycle battery it's been in my truck for 7 years now it always starts right up and it sits for months at a time.
Originally Posted by 4RETECH
Hey guys,
My battery is getting weak.But at 192,500 and being a 2003 it's okay,I can deal with it.
I am trying to find out the replacement number and someone said it was a 35.
Also, I want to know if anyone has had luck with either a red top Optima or an interstate.
I can get the interstate for 68.00 since I work at a shop, but figured maybe a red top would be good.
I don't really need the race battery(right now).
Thanks for your help.
Old Jun 16, 2010 | 06:13 AM
  #87
codgi's Avatar
So thats what that red thing was? . I thought it was just a cover. After I saw this pic, I went out to the garage and sure enough on that part it says "use under battery as necessary." In fact the one I got came with a 2 part one (A and B). The one above looks like the "B" one so I'll try just that one. Thanks a lot! .
Old Jun 16, 2010 | 02:17 PM
  #88
SpoolinUp's Avatar
Silver Sponsor
Used stock tray, SS 1/4" threaded rod, 2x SS wingnuts, 4x SS washers, 1x SS nyloc nut, A brad-holt T-nut from lowes (used on right side holddown rod), and some strap aluminum. Probably cost $100 max with battery.
Thanks!
-Franc
Attached Thumbnails Battery Replacement.. opinions OEM style-img00198-20100616-1656.jpg
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jun 16, 2010 | 05:52 PM
  #89
JDM-Evo9MR's Avatar
Bro, I'm at the end of this thread cause i'd definately like to see pics of your car. I think i'd definatley let you drive my car. lol.
Old Aug 22, 2013 | 07:25 AM
  #90
Kreeker's Avatar
Reviving this thread.
Are the more expensive batteries, like the Optima Red, worth it for someone who has no plans in doing major audio work?
