Injen Intake Hitting ACD Reservoir?
Old Mar 4, 2010 | 10:05 PM
bboy_RES's Avatar
my injen filter is hitting the ACD reservoir which put a dent into the filter. does anyone else have this problem? how did you guys fix it?
Old Mar 4, 2010 | 10:45 PM
turbotalawd's Avatar
Do you have just the filter or the whole kit? I have the filter, intake pipe, and upper and lower injen ic piping and have no problems.
Old Mar 5, 2010 | 01:23 AM
blownevo's Avatar
Mine does that, but I have the ETS Intake Kit.
Old Mar 5, 2010 | 01:28 AM
MR. EVO MR's Avatar
You didn't install I correct, I had the same problem when I realized you can tilt it slightly
Old Mar 5, 2010 | 12:34 PM
Originally Posted by mr. Evo mr
you didn't install i correct, i had the same problem when i realized you can tilt it slightly
+1
Old Mar 5, 2010 | 12:50 PM
jos's Avatar
jos
yeah just ajust the position of the intake pipe until it clears the area.
Old Mar 5, 2010 | 03:15 PM
miller121mx's Avatar
If in fact it IS installed correctly and still hits, then I think Injen needs to work on their quality control. On my UICP I got in the intake kit, I had to cut over an inch off the tube going to the BOV for it to be remotely close to fitting.
Old Mar 6, 2010 | 04:18 PM
bboy_RES's Avatar
i'll try tilting it and see if that solves the problem. i had the same intake/ic pipe kit on my last evo and had the same issue with that.
Old Mar 6, 2010 | 05:29 PM
FQ-300's Avatar
I swapped the supplied Injen filter with a K&N RF-1005. Fitment is perfect along with added visual appeal.
Old Mar 7, 2010 | 01:30 AM
MR. EVO MR's Avatar
Your filter is injen too? You just have to make sure everything is pushed in tight and it shouldn't hit.
Gl
Old Mar 7, 2010 | 10:34 PM
amsevokid's Avatar
mine was doing the same thing but then i just turned the filter and it fits perfectly.
Old Mar 7, 2010 | 11:13 PM
bboy_RES's Avatar
Gl
yup. it's the injen filter. i'm gonna have to replace it though since it has a nice little dent on it from hitting the ACD reservoir. i'm gonna reinstall my ic pipes and injen intake to make sure i installed everything correctly.
EnjoyDriving
Dec 28, 2015 12:48 PM
Viegasjuice
Oct 12, 2014 06:45 PM
kaonashi
ExtremeTurboSystems.com – WA
Apr 1, 2013 07:53 PM
kmartizdatruth
Oct 9, 2009 09:08 PM
