Clutch
Old Apr 27, 2010 | 09:50 AM
Nofear23's Avatar
Clutch
Hey,
I've had my car for a couple weeks now. I've noticed the clutch is very hard to get used to. It has to be let ALL the way out to engage (which I know you can adjust the engagement in some, but I've read that can also cause shifting issues)... but not only that, but it is very "touchy" and engages very fast. I let a fellow evom member drive it, and as he describes it, its like an "on/off" switch. The entire car is stock. Could it have an aftermarket clutch? Is there any way I could make it a bit more drivable? Fast shifting is basically impossible the way it is.... Thanks for the help.
Old Apr 27, 2010 | 09:59 AM
thedru13's Avatar
Pop off the trans inspection plug see what the clutch is. Can see if its aftermarket. I would try the pedal adjustment also check the shifter cables/bushings.. start there. Then check the slave cylinder and fluid level..
Old Apr 27, 2010 | 10:13 AM
Nofear23's Avatar
Where's the inspection plug? I'll be down there changing the fluids this weekend anyway so that works out.
Old Apr 27, 2010 | 10:21 AM
thedru13's Avatar
look on the bottom of the bell hosing you should see a plug
Old Apr 27, 2010 | 10:33 AM
chaotichoax's Avatar
certainly doesn't sound like the clutch is stock
not much you can do to change the light switch feeling
Old Apr 27, 2010 | 10:39 AM
Nofear23's Avatar
I miss the Exedy I had on my Eclipse If this one is aftermarket I wonder why its so much harder to drive.
Old Apr 27, 2010 | 10:46 AM
rcheung's Avatar
An on/off switch sounds like a puck clutch.
Old Apr 27, 2010 | 11:49 AM
C_LosEvo's Avatar
if its an aftermarket clutch thats how they are. I have an exedy stage 2.
Old Apr 27, 2010 | 12:20 PM
Nofear23's Avatar
How do you drive the damn thing!?!?! Taking off from stop lights I have to let it out very slow so I don't let it out too fast and make the car jump like an idiot!But I end up looking like an idiot anyways because I sit there longer than everyone else trying to careful.
Old Apr 27, 2010 | 12:37 PM
C_LosEvo's Avatar
you get use to it. i daily drive my car in LA traffic. The only time is a pain is when your in a hill because of the way the clutch engages.
Old Apr 27, 2010 | 12:38 PM
Nofear23's Avatar
Is your engagement point almost all the way out on yours? I could still try and adjust it so its closer to the ground some.
Old Apr 27, 2010 | 12:43 PM
rcheung's Avatar
If it is a puck clutch, which I think it is, it takes alot of getting used to. Its not so bad with a 6 puck but a 3 or 4 puck is pretty ridiculous for daily driving.
Old Apr 27, 2010 | 03:42 PM
C_LosEvo's Avatar
yeah its very high even after i adjusted. yeah i have a 3 puck clutch.
Old Apr 27, 2010 | 03:49 PM
turbotalawd's Avatar
Originally Posted by rcheung
if it is a puck clutch, which i think it is, it takes alot of getting used to. Its not so bad with a 6 puck but a 3 or 4 puck is pretty ridiculous for daily driving.
+1
Old Apr 28, 2010 | 08:43 AM
Nofear23's Avatar
Every once in a while when I let up off the clutch and start moving, I hear a rubbing sound, almost like the brakes are rubbing. But I obviously am not touching the brake pedal. Could this have to do with the clutch too?
2012EvoXGSR
May 9, 2014 04:47 AM
cmross13
May 30, 2013 07:43 AM
Beetlebrox
Sep 23, 2012 11:30 AM
BoostedAWD91
12
Jun 29, 2012 11:49 AM
JEP
May 13, 2011 05:55 PM
