Rain = Sputtering?
Old May 20, 2010 | 06:49 AM
tdubbz's Avatar
Rain = Sputtering?
I don't know if this is a common problem with Evo's but when its rains outside my car does not like it. The car will begin to sputter when driving around town. I opened the engine bay to check if my intake was getting wet and it is not. I can't think what the issue could be. The car had this issue when it was stock too so it doesn't have anything to do with the mods. When its not raining no issues whatsoever.
I'm confused....
Old May 20, 2010 | 06:54 AM
4RETECH's Avatar
I used to have the same problem. But I used to get a check engine light, Throttle position code. One day I just checked the Throttle position sensor wiring, added some di-electric grease and have never had the problem again.
Old May 20, 2010 | 03:35 PM
fwd_josh's Avatar
mine did something similar and water was getting into the connector for my MAF, i eventually had to replace my MAF, since it had been going on before i bought the car too. rotated the MAF, with some dielectric grease in the connector and it's all good now.
Old May 20, 2010 | 05:57 PM
jy951's Avatar
Maybe check the coils/wires/plug conections.
Old May 20, 2010 | 06:12 PM
tsidrift1's Avatar
Check for electrical gremlins in the lower left kick panel.
Old May 20, 2010 | 07:25 PM
tdubbz's Avatar
thanks guys I will check that out. Hopefully it does the trick because its really annoying.
Old May 23, 2010 | 09:33 AM
a_awdgsx's Avatar
when its humid or wet weird things happen with electrical stuff. My evo used to not start when it rained. Turned out it was water getting on the starter cable
Old May 23, 2010 | 09:28 PM
pennies_hatchie's Avatar
I would check to see if water was getting in and hitting any electrical things. GL
Old May 23, 2010 | 09:35 PM
detroit pistins's Avatar
https://www.evolutionm.net/forums/in...s-how-fix.html
Old May 23, 2010 | 10:18 PM
j03yYunG's Avatar
its been raining like crazy the past week, and I havent had any issues with sputtering.
Old May 27, 2010 | 06:31 PM
intuition_d's Avatar
For a second I thought hydrolock. Thank god not
Old Jun 6, 2010 | 11:43 PM
e.v.o IX's Avatar
plus one as well... no issues on sputtering.. **knock on wood**
Old Jun 7, 2010 | 06:37 AM
iicemanr6's Avatar
I get a similar issue just from the change in the weather. mine tends to kick a random engine misfire code. but it tends to only be when the weather changes. usually only a problem until the car warms up fully. but if it stays rainy or snowing or dry, there is no issue.
Old Jun 7, 2010 | 06:46 AM
SuperMoto!'s Avatar
It's been a very wet sprint this year and I have not had any issues like your. Good luck running it down.
papabeardoe
Jun 13, 2017 04:06 AM
guapoholic
24
Feb 24, 2017 07:47 PM
jmrussell89
Mar 17, 2016 06:34 PM
Igaly1021
Nov 7, 2015 05:18 PM
Firm
Jan 21, 2012 01:31 AM
