Ground cable
Old Jun 17, 2010 | 09:56 AM
benselements41's Avatar
Ground cable
Does the ground cable in a evo 8 connect from the ground terminal battery post to the starter?
Old Jun 17, 2010 | 10:12 AM
RoadSpike's Avatar
The post on the starter is a positive lead. There are two posts because its a relay and it simply bridges that gap when its fired. If you put a ground on the second nut it will short out your battery when you try to start it.
The correct spot for the positive lead is the post furthest away from the motor or in other words the post closest to the front of the car.
Old Jun 18, 2010 | 01:13 PM
DarksideZ's Avatar
What he said. Shorting your battery can possibly kill your ecu, so be very careful.
Old Jun 18, 2010 | 01:22 PM
jmelocik's Avatar
Wait? what? The starter has a positive lead from the battery, it also has a ground which bolts to the transmission case and uses the case as a conductor to ground for the battery.
Josh
Old Jun 18, 2010 | 01:38 PM
cssaddictm4's Avatar
Josh
I think I am missing the ground from the starter to transmission case. This is maybe why I have a slow crank... Good info Josh!
nor11384
Apr 2, 2017 10:44 PM
supersnow
May 25, 2016 02:53 PM
bigben
May 17, 2012 03:39 PM
gatsu
Evo X How Tos / Installations
Aug 22, 2011 12:54 PM
EvOSean06
Apr 4, 2010 07:10 PM
