Advice FP Red vs. Fp Black
Old Oct 29, 2010 | 05:00 PM
suby2evo's Avatar
Imo when it comes to FP turbos there's two options HTA green or the black, it's like filling gas there's regular or premium. Who fills mid grade?
Old Oct 29, 2010 | 05:06 PM
evo8426's Avatar
the guy with the boosted honda..jk
i would go with a green over the black on a non built engine, on a built motor i would choose the black because then you can put the turbo to some real use by letting it run high boost
Old Oct 29, 2010 | 06:19 PM
SpecialNeeds's Avatar
are both red and black journal bearings?
Old Oct 29, 2010 | 06:32 PM
EVO8LTW's Avatar
Yes. The difference is pretty much only the compressor wheel.
Old Oct 29, 2010 | 09:33 PM
sportsallstar's Avatar
thanks for all the awesome info guys. Going with the black would have a much more fun top end once things were built and pushing mid 30 psi. But built motor, tcase, tranny and another new clutch are going to kill me. Such a difficult decision lol
Old Oct 29, 2010 | 09:58 PM
awdwannabe's Avatar
The T-case and trans will be fine with the black.. the clutch on the other hand.. depends on what your currently running. Like I said before as long as you stay around the 500whp area you should be safe with the stock motor, but if you push it above 550+ you might be asking for a motor upgrade as well, and maybe a new hood if the rod decides to let go on an up-stroke. Also with the Black as stated earlier, you have to use a different kind of oil just for protection and lubrication.. There's a thread started about it on here somewhere as well.
Old Oct 31, 2010 | 01:21 AM
rdt1's Avatar
I can't wait to see how the fpblack runs!
Old Oct 31, 2010 | 02:32 AM
JohnDoe1984's Avatar
For a stock block a black seems like a ticking time bomb. It's hard to buy a journal bearing turbo with that new HKS GT7640 out. That's the turbo to buy for a stock block right now IMO. HTA green performance without the journal bearing.
Old Oct 31, 2010 | 09:27 AM
eron28's Avatar
black for sure...
Old Oct 31, 2010 | 09:31 AM
murlo26's Avatar
I know this is for the X but very similar turbos. My Fpred on E85 stock block vs FPblack on E85 built motor...the difference in lag is so minimal but the gains are there big time.
http://dbptuning.com/dyno/graph_data...ata_type=boost
Old Oct 31, 2010 | 02:42 PM
AdamWest's Avatar
both are sick turbos
Old Oct 31, 2010 | 03:02 PM
EVO IXMR's Avatar
If you want your motor in one piece I would get the black.The black has a bit more lag and has a different tq ramp up then the red.Tq and how it hits keeps your block together and so does the tune.If I was you ask for a soft pump gas tune..
Old Oct 31, 2010 | 03:09 PM
cij911's Avatar
HTA Green IMHO .... See my power curve in the dyno section - a very basic setup w/ wide power band and 440 whp ....
maddenth
10
Sep 6, 2013 10:13 AM
Mikey@Spec-Ops
92
Dec 12, 2011 09:47 PM
RSMike
49
Jun 22, 2011 04:37 PM
5LEEPERISAH23I
11
Jul 15, 2010 04:46 PM
BLKCarbonEVO
Jun 29, 2010 07:56 PM
