mbc, ebc, 3port
Old Nov 4, 2010 | 05:18 PM
Raptord's Avatar
Originally Posted by detroit pistins
Thanks alot for the pm, lots of great info that are somewhat over my head
ps. u should probably share the info u sent me on here.
No problem
Summary of what I said for others:
I'm running Tephra v7 with a JDM MAP sensor and a Grimmspeed 3-port BCS. I'm using PSI-based direct boost control, so once I set my boost curve the ECU will adjust as necessary to get me whatever boost I'm asking for. Additionally, with v7 you can use the MAF IAT WGDC Correction table which, once you get it setup properly, should get you your desired boost whatever the air temp is. You just have to take the time to tune it properly, then you can forget about it
Old Nov 4, 2010 | 06:36 PM
volcano's Avatar
All,
Thanks for the quick responses - very much appreciated. Based on the feedback it looks like the mbc might be the better solution.
Thanks.
Old Nov 5, 2010 | 12:08 AM
EvoJoeIX's Avatar
have to admit that iam not familiar with the bleed type! how does it deliver the signal to the wga all at once or doe sit ramp it up?
ex. if i set it up at 24psi, would the wga see a 24psi signal all at once, or would the "bleeding" mbc ramp up?
Bleed type let's boost "bleed" to the wastegate which makes you see full boost slower then the kind with a ball and spring. You will see full boost all at once with a ball and spring boost controller
Old Dec 24, 2010 | 03:45 PM
silverevo05's Avatar
looks like a MBC will be better for my setup than an ebc
Hallman RX I guess
mitsubeastlee
15
Oct 30, 2014 05:54 PM
maxroach
Feb 11, 2014 04:12 PM
88888
18
Dec 10, 2011 08:16 PM
Koroshiya
Jun 4, 2009 09:51 AM
TREVORSEVOVIII
16
Aug 7, 2007 12:24 PM
