Drop-in filter vs. Cone.
Old Nov 11, 2010 | 06:57 AM
e4on2e5's Avatar
Evo's come with a very rich map (tune) from factory so getting more air in/out by way of a intake/exhaust won't hurt performance, your actually doing ur car a favor... a tune is not needed for these mods... but it is ofcoarse recommended if u want to get the most hp from the boltons...
Old Nov 11, 2010 | 10:11 PM
domyz's Avatar
I'm not sure that this will not enrichen the mixture because the MAF will see more air and will exgareate the enrichement
Old Nov 11, 2010 | 10:27 PM
4G63kevin's Avatar
Get a Drop-in and call it a day. If you;re going to run a cone, might as well make a heat shield around it because the majority of the air it's sucking is the heat from the exhaust mani area.
Old Nov 17, 2010 | 08:11 AM
deeman101's Avatar
+1
Not necessarily. As long as the car is moving forward it should be getting cool air from outside. The exhaust manifold heat should escape through the vent in the hood.
Old Nov 17, 2010 | 08:57 AM
FJF's Avatar
FJF
What happens when the car is not moving in traffic and the AC fan kicks in?
Old Nov 17, 2010 | 09:19 AM
deeman101's Avatar
You draw in lots of hot air. Good thing your engine isn't under heavy load.
Seriously though I've logged my car just sitting stationary and it was like 10-15 higher than outside air temp @ 17 degrees celcius. That was with the rad fan coming on and off.
Old Nov 17, 2010 | 09:45 PM
sparky's Avatar
Huh. Of course not much is happening when idling in traffic, or parked with the engine running. A good sound system is more important than a good air filter under these circumstances....Duh!
Old Nov 17, 2010 | 11:48 PM
AdamWest's Avatar
Originally Posted by Rnm
I remember when I got my Perrin intake and retuned from the stock box, I gained about 40whp. This was all done on E85.
40whp is impressive off of an intake.. what are you running for whp now??
Old Nov 29, 2010 | 09:03 AM
4g63Moon's Avatar
ETS intake is nice and i would get the perrin spungy filter which has been proven to
make the most power/trap the debris real good.
Jingming88
Apr 7, 2012 10:12 PM
GetterDragun
Oct 19, 2010 07:39 PM
Ltdanish07
23
Mar 26, 2010 08:14 AM
mantosride
10
Jul 20, 2009 10:10 PM
jonsevo
11
Apr 30, 2008 04:50 AM
