idle issues
Old Dec 4, 2010 | 11:23 AM
ahh3917's Avatar
idle issues
Hey everyone, 04 evo, 46xxx miles... car idles fine just sitting there but lets say im at a light and i go to drive off and then i have to stop real quick like the guy in front of me doesnt move, the idle drops to 200-400 for a moment and then catches it self and then goes back to normal... def happens if on a hill if im rolling back tthen move forward say a few feet then press the clutch in and take my foot off the gas. Any time under a bit of load. Car runs great other than that. Car does have Cams.
Things i have done...
Cleaned MAF and TB
boost/vac leak test-None
Recirc BOV so that shouldnt be causing it
IAC- tested at 30 ohms ( still might pick up another one for cheap if i can and replace that)
Tuned (Twice). doesnt help and they say everything is fine.
TPS sensor was a little off but fixed that
Running out of ideas. Any suggestions? Thanks in advance!!
Mark
Old Dec 4, 2010 | 11:37 AM
coneman's Avatar
Dose this happen with the defroster or A/C on or off. My car dose the same only with the A/C or defroster running.
Old Dec 4, 2010 | 12:35 PM
ahh3917's Avatar
well it does it with out it on so im going to assume it will happen with it on... if i leave the car on and turn the wheel all the way to one side then turn the air on it doesnt really drop at all
Old Dec 4, 2010 | 12:53 PM
nj_08_gts's Avatar
EGR, PCV, & vacuum control valves all worth having a look at.
Unlikely but possible culprits: Upstream o2 sensor, MAP sensor
Old Dec 4, 2010 | 12:58 PM
Raptord's Avatar
This is EXACTLY the same problem that I have on mine. Running the car in open loop below ~1700 rpm helps, but doesn't always fix it, especially if I quickly have to let off like you describe.
I'm still looking for a permanent solution, definitely subscribed to this.
Old Dec 4, 2010 | 01:07 PM
nismos13sleeper's Avatar
Start at Egr.my cars does it a little bit sometimes also but I haven't found a solution yet.gl
Old Dec 4, 2010 | 01:10 PM
gieri002's Avatar
I have the same problem, subscribed.
Old Dec 4, 2010 | 01:26 PM
Raptord's Avatar
When you say "worth having a look at", do you mean taking out the valves and cleaning them, replacing them, or something else? And which one is the vacuum control valve? Do you mean the IAC?
I've already changed the o2 sensor, so that's not it.
Old Dec 4, 2010 | 01:33 PM
nj_08_gts's Avatar
For the PCV, just install a new one since they're so cheap. For the EGR and check valves, yes...clean them out. I'm not sure the exact location of the vacuum check valve in your car, but it's probably a little elbow joint looking thing near the brake booster.
Old Dec 4, 2010 | 07:59 PM
seatsr4couches's Avatar
I'm also having this issue... subscribing...
Old Dec 6, 2010 | 10:58 AM
Durgyness's Avatar
this is interesting, anyone else know of anything else that could cause idle / stalling issues?
Old Dec 6, 2010 | 11:06 AM
Bad gas maybe? now that i'm thinking about it I've got 91 in because 93 was not available. I'll update once I get the right stuff in
Old Dec 6, 2010 | 09:12 PM
nnb239's Avatar
What cams are u on?
Im on 272s with reflash, once my a/c is on my car dyes off when im at a complete stop
But im used to this already
Old Dec 7, 2010 | 09:35 AM
rob328's Avatar
subscribed, but mine just happens when the heat in on.
Old Dec 7, 2010 | 09:42 AM
Durgyness's Avatar
If the car has been tuned would it still be the cams?
