help rough idle n sputtering after 3000rpms. ive searched a lot!!!
Old Dec 10, 2010 | 10:50 PM
amsevokid's Avatar
hey everyone so after putting in new spark plugs in my evo 9 for some odd reason the car has been idling hiring than normal, the vacuum is also a little higher, also wen in neutral if i step on the brake the cars idle drops to almost 300rpms then bounces to 900 rpms, n it fluctuates until i let off the brake, and wen cruising after i hit above 3100rpms the car starts to sputter until i have to press harder on the gas pedal. can anyone help me, ive been seraching all around n have had no luck please any insight would be greatly appreciated.
Old Dec 11, 2010 | 12:55 AM
FJF's Avatar
FJF
Which spark plugs did you install?
Old Dec 11, 2010 | 04:55 AM
4RETECH's Avatar
Did you double check the throttle cable as you might have kinked it or moved it to install the plugs?
Old Dec 12, 2010 | 12:29 PM
amsevokid's Avatar
i installed ilfr7h ngk iridium spark plugs
Old Dec 13, 2010 | 08:23 AM
Jerm__'s Avatar
Did you gap them correctly? i would also check the throttle cable as mentioned above
Old Dec 13, 2010 | 02:12 PM
tarmac03's Avatar
+1 check the gap
Old Dec 15, 2010 | 09:42 PM
amsevokid's Avatar
on the forums it was recommended to gap them .20 -.24 n the spark plugs came gapped at .20 already so i just put them in, i checked the cable n its fine, so should i gap them higher?
Old Dec 15, 2010 | 09:44 PM
k20toEVO's Avatar
check your charge pipes and may one blew off ?
Old Dec 15, 2010 | 09:52 PM
amsevokid's Avatar
i might sound like a newb but wuts a charge pipe?
Old Dec 15, 2010 | 10:42 PM
JonahEVO's Avatar
Check your Intercooler pipings if It's loose.
Old Dec 16, 2010 | 06:23 AM
amsevokid's Avatar
Lol ok, sorry I just never heard them be called charge pipes, but after work today I'm ganna re check everything including the ic pipes, thank u all for your help and advice. Hopefully she will be running good before the snow gets here, I want to have some awd fun
Old Dec 17, 2010 | 02:19 AM
k20toEVO's Avatar
sorry charge pipe, intercooler pipes ect. all the pipes connected from throttle body to turbo. Usually when I blow off a pipe it runs like you explain it. I since then upgraded to T-Bolt clamps becuase I have so much pressure going through.
kpr
14
Apr 24, 2024 12:42 PM
papabeardoe
Jun 13, 2017 04:06 AM
CarrelliEvo8
Dec 2, 2016 09:02 AM
Igaly1021
Nov 7, 2015 05:18 PM
merlin00069
Apr 27, 2009 08:56 AM
