AEM UGEO wideband problem.HELP?!?
Old Jan 31, 2011 | 07:57 AM
LivinloudEvo's Avatar
While driving today i noticed my wideband was stuck on 14.8 no matter how much throttle I gave the car or when I let off it stayed at 14.8 once in a while it would move to 14.7. I parked the car turned it off and back on still having the same problem. Does anyone have any suggestions on what the problem might be or how to fix this?
Thanks
Old Jan 31, 2011 | 09:03 AM
white_evo27's Avatar
Thanks
this is my exact problem also... seems like everyones sensor is dying at the same time
at first i thought my fuel pump was dying, but then i did the brake cleaner test on the sensor and it came up bad... the test is posted in another thread on here, this has been a recent topic lately lol...
hope this helps!
Old Jan 31, 2011 | 09:12 AM
escodotcarter's Avatar
check to make sure the connection is tight. check the clip. This happens when you have power to the gauge but not to the sensor. (i.e. i had my gauge installed and powered on but didnt install the sensor till a few days later and the gauge would stay at 14.7 and occaisonally move to 14.8)
Old Jan 31, 2011 | 11:05 AM
awdordie's Avatar
Search first. Like white evo said there's two or three post on this one is a member name pirana. My gauge is doing this as well. Pirana informed me he ordered a sensor to see if that was his problem and will let me know if that was his problem.
Old Jan 31, 2011 | 12:40 PM
EvoJoeIX's Avatar
search. i dont know how many times i posted how to check an AEM wideband sensor on here. i know i just recently posted one for sure
Old Jan 31, 2011 | 12:46 PM
Night479's Avatar
Clean it, it coule just be carbed up I whipe mine when I rotate the tires. Or just buy a replacement its like 80 or something
Old Jan 31, 2011 | 02:37 PM
VKEVO's Avatar
You should check this for sure. It happened to mine because the clip wasn't in tight.
Old Jan 31, 2011 | 03:43 PM
Pirana's Avatar
Ok, went thru this this weekend....your sensor is bad....I replaced mine yesterday and viola! worked to perfection.
Insanity Evo
Jun 14, 2016 06:45 AM
Junkyardspecial
Aug 11, 2015 06:23 PM
Wht9er
Nov 28, 2012 04:34 AM
toolmanblink182
Lancer How Tos / Installations
25
Jul 29, 2011 07:23 AM
Pirana
18
Jan 31, 2011 07:50 AM
