Launching the Evo
Old Feb 14, 2011 | 08:03 PM
  #31
Raptord's Avatar
My tip: start practicing without flooring it all the way. Just give enough throttle to get to your 2-step and hold that until after the launch when the clutch is fully engaged, then floor it. You'll get an idea of how fast you need to release the clutch without picking bits of your tranny or clutch off the pavement.
And +1 for ODUB's method. In theory it's really simple, but things happen real fast when you try it for the first few times. I wasn't flooring it at first but I realized I still wasn't releasing the clutch fast enough after it had started engaging. I could smell it after my first try. Once it starts engaging you need to VERY quickly release the rest. That's why I recommend starting from a lower rpm/TPS to get a feel for it.
Old Feb 14, 2011 | 08:23 PM
  #32
joseph143's Avatar
granted his way isnt that harmful to a clutch but youre still technically burning the clutch having it partially engaged... i dont see any advantage in partial engagement but i dont see any real down side either... personal preference is all that really is.
and i'm with the guy who said if you cant afford to break it then dont bother to begin with. if i shatter my tranny then shep or tre will be my new best friend for a month and i'll be out on the track about 1000 miles later...
anyway best of luck to you... i hope you get the launch down the way you like it.
Old Feb 14, 2011 | 08:31 PM
  #33
bfresh's Avatar
Someone should make a tutorial, all you would need is like 3 camera and 2 people.
Camera A - Whatchin dash
Camera B - Whatching Pedals(Clutch,break, Gas)
Camera C - Whatching Driver.
just my 0.02
Old Feb 15, 2011 | 04:43 AM
  #34
Raptord's Avatar
just my 0.02
I could do just that actually. Anyone want to donate funds for a launching
tutorial to pay for the new clutch I'll need after I'm done?
Old Feb 15, 2011 | 10:14 AM
  #35
xcelr8's Avatar
Originally Posted by ODUB
/thread
Follow this technique above. But your t case is never safe. Better when launching on slicks so that the tires are moving in synch. When some or one tire isnt getting traction and others are or they are moving at a different pace, thats what destroys drivetrains.
Old Feb 15, 2011 | 10:51 AM
  #36
mexfizzle's Avatar
i got mines at 6k and it grabs nasty ... i ran 11.5 at 119 with stock block and tranny and evo 9 turbo.. =)
Old Feb 17, 2011 | 08:29 PM
  #37
4g63Moon's Avatar
Honestly, you just need experience and learn from it. People have their own way of launching and so should you. But 3k is too low, and there is a reason why Evos have 2 step aka launch control. Get on it
Old Feb 17, 2011 | 11:27 PM
  #38
Nastynine's Avatar
3k will prolly do more damage that good. you'll bogg like crazy.
a lot of ppl say "slip" you almost wanna do a mixture of slipping/dumping. u dont wanna dump but you dont wanna slip. try and get it right in the middle you know? depending on the kind of clutch you have also contributes
Old Feb 18, 2011 | 01:13 AM
  #39
apexct9na's Avatar
Originally Posted by WolfsFang
Dont dump the clutch. Better off to burn the clutch then to break something down the drivetrain
I can totallly vouche for this guy i never ran my evo nor launched it yet i have 5500 rpm 2 step i got to line staged up 2 step..... to clutch dump with act 2100 stage 2 clutch made 5 runs and kabooooom spider gears go bang...... i stay in it all the way down the track like an idiot and still hit a 13.206at 105 mph yeahh had my car a month and a half and its sat since sept. N yeah im bout 1200 n the hole on a car i still owe 13 grand on lmao priceless huh. Hopefully n 2 weeks ill be rollin it again got everything for it finally.
Old Feb 18, 2011 | 02:26 AM
  #40
ezz-e's Avatar
Slipping the clutch is the best way to save your drive train parts and get the best 60 foots. ask all the big dogs why they do it.
Old Feb 18, 2011 | 09:53 AM
  #41
03upstatefire's Avatar
Stock 2-step is set for 5500, when I picked my car up the 2-step was set for 6200, should I be worried launching the car with this increase?
Old Feb 18, 2011 | 10:36 AM
  #42
Raptord's Avatar
What mods? (clutch and turbo in particular) (and isn't stock 5k?)
Old Feb 18, 2011 | 06:43 PM
  #43
evolutme's Avatar
03 evo's rev limiter is set at 6200. just get a tune and you can set it down to 5500
Old Feb 18, 2011 | 07:32 PM
  #44
Not sure about what the stock 2step is but clutch is stock and turbo aswell. on 24psi. only 39k on the car
  #45
So it just comes with 2step at 6200 factory?
audiofan
Apr 3, 2011 05:36 PM
ilovemye46nevo8
16
Jul 13, 2007 02:47 PM
alright by me
Oct 21, 2004 07:30 PM
Gary U
Aug 15, 2004 06:14 PM
IS2000
Dec 4, 2003 12:32 AM
