weird throttle noise???
Old Feb 19, 2011 | 01:07 PM
white_evo27's Avatar
at 20% throttle i get this ringing sound from the engine bay area, it sounds like something is rattling around and havent been able to figure out the cause of it... the weird thing is that the noise relates to the amount of gas i give the car... 20% and under it makes the noise, and above 20% it goes away... (was logging with AEM to see the throttle position) im confused i looked for loose bolts, etc and found nothing.... anyone have any ideas?
Old Feb 19, 2011 | 01:23 PM
also forgot to mention that sometimes while turning i can feel a vibration through the gas pedal, sometimes its bad, sometimes not.
Old Feb 19, 2011 | 08:08 PM
Chadwich's Avatar
I had that issue a little while ago.
I don't know if it will help or not, but in my case it ended up being a bad shock / tie rod end on the pass side of the car.
I had the same feeling in the gas pedal.
hope that helps
Old Feb 20, 2011 | 08:31 PM
awesome thanks for the help, gonna check that out!
jetc33
Mar 15, 2012 02:42 PM
Codeman17
Nov 28, 2007 09:14 PM
NwO 2k Mouse
Lancer Troubleshooting
Aug 16, 2005 06:52 PM
JaReDbOy
15
Aug 24, 2004 07:38 PM
Hanzo
May 16, 2003 02:02 PM
