Titanium exhaust trouble !!
Old Feb 28, 2011 | 10:56 PM
armak's Avatar
guys i have an evo 9 mr with a full Titanium exhaust from trust.
i was driving and when i shifted to 3rd gear at 7,000 rpm the mid pipe between the muffler and the test pipe fell .
i think it wasnt welded proparly.
Do you think it will happen again after welding it?
Old Feb 28, 2011 | 11:00 PM
STi*guy.kiev's Avatar
Best bet, v-band your test pipe. Titanium has trouble being welded to steel
Old Feb 28, 2011 | 11:57 PM
elementsk8erq's Avatar
If you want it welded correctly you have to go to a exhaust/muffler shop that specifically welds titanium. It may be pretty hard to find a place that does that and will probably be pretty expensive.
Old Mar 1, 2011 | 01:01 PM
88_Pathy's Avatar
Pictures would be nice. Are there no flanges? Did the weld clearly break? Is it a slip fitted system? There alot of variables. But I would say that not many places around you will weld titanium properly.
Old Mar 1, 2011 | 02:01 PM
EvoJoeIX's Avatar
the easiest/ cheapest route would be to goto an exhaust shop and have them make a slip fit test pipe out of stainless steel, cut off the flanges on the downpipe and cat-back(if there are any) and just slip in the SS test pipe....thats what id do because like stated earlier, its going to be hard to find someone to weld titanium
Old Mar 1, 2011 | 10:15 PM
armak's Avatar
guyz..is it possible if i changed this part and ask an exhaust shop to manufacture a SS pipe?
Old Mar 1, 2011 | 10:47 PM
Benja's Avatar
Common fault on the Trust Ti.
Old Mar 1, 2011 | 11:36 PM
reboundicon's Avatar
I think the tomei is also made of titanium and I have heard stories of other owners running titanium exhausts having issues with getting them repaired. Your best bet is to slip fit a test pipe as not many shops will be able to weld titanium.
Old Mar 2, 2011 | 12:02 AM
evosam726's Avatar
need pics brO i have the same exhaust
Old Mar 2, 2011 | 02:49 PM
Vehicle336's Avatar
Ditto on the pics, as I have the same exhaust.
Old Mar 3, 2011 | 12:20 PM
MyEv08u's Avatar
i heard of that problem with the trust Ti exhaust, so i got a JIC magic one....no problems shifting at 9500k (just alotta fire -__-) , take it to a exhaust shop and have them see what they can do to fix it!
Old Mar 3, 2011 | 01:02 PM
EvoJoeIX's Avatar
please tell me how the rpms where you shift affects your exhaust
Old Mar 4, 2011 | 02:39 AM
bcrance13's Avatar
/\/\this!
Old Mar 4, 2011 | 02:37 PM
aggieEVO's Avatar
You didn't hear an exhaust leak up until now?
Old Mar 4, 2011 | 02:46 PM
stamlon's Avatar
Titanium cannot be welded to Steel. Not at all.
413EVO
Oct 5, 2013 03:10 PM
ashwill
50
Jul 15, 2011 02:09 AM
benderrodriguez
Jun 9, 2011 12:06 PM
Girodisc Martin
109
May 1, 2011 02:09 PM
Nez136
Mar 23, 2005 09:24 AM
