downpipe help
Old Mar 9, 2011 | 05:06 AM
clubEVO93's Avatar
downpipe help
Last night i tried to install my turbo back, and i couldnt get the bolts on the downpipe to move at allboo and i was afraid if i tried any harder i would brake the bolts off inside. So does anyone have an idea on how to help me?
Old Mar 9, 2011 | 05:14 AM
TeStUdO's Avatar
The bolts that attach to the O2 housing or the ones that attach to the cat converter? Get some PB Blaster and soak the bolts overnight. Use a breaker bar for leverage or impact wrench if need be.
gsrboi80's Avatar
PB Blaster the crap out of them, Use air tools if you have them.
I usually just cut any and all exhaust bolts and use new less aggravation
Old Mar 9, 2011 | 05:15 AM
sharkm87's Avatar
you have to use pb blaster or wd 40....gotta soak it alot sometimes...spray it and let it work its way threw
Old Mar 9, 2011 | 07:31 AM
r0xah's Avatar
**** sucks without the right tools
Old Mar 9, 2011 | 11:47 AM
Creativeindy's Avatar
I got lucky on my 05 and they screwed right off... my 06 was a different story. What I did was spray the crap out of them with PB Blaster, let it sit for an hour, then I drove the car tog et the bolts heated up and I came back and they came right out.
Old Mar 9, 2011 | 04:18 PM
clubEVO93's Avatar
What did you cut them with?
Old Mar 11, 2011 | 03:57 PM
gsrboi80's Avatar
Usually a wiz wheel. But if you have no air a sawzall will work
Old Mar 11, 2011 | 04:45 PM
scothu's Avatar
breaker bar worked for me
Old Mar 11, 2011 | 05:09 PM
JJsevol's Avatar
Soak in PB or WD-40 and use a breaker bar and extension.
Old Mar 11, 2011 | 05:15 PM
wht95scort's Avatar
Believe it or not but pour a cap full of brake fluid on the bolts and wait a min or two. It works.
Old Mar 11, 2011 | 09:28 PM
SickEvoVlll's Avatar
i have a 03 Evo i changed the down pipe from stock to a Megan down pipe an now when 2nd or 3rd gear on a heavy load it kinda wants to choke out an spudders what can cuz it to do that?
dsmturbo87
Evo X How Tos / Installations
10
Feb 1, 2014 12:39 PM
ahendrickson
Apr 16, 2013 05:58 AM
rmrEVO
Apr 22, 2012 11:16 AM
Audi2Evo
Jul 20, 2010 01:17 PM
Go2fast
Lancer Aftermarket Forced Induction Tech
Jan 26, 2006 03:13 PM
