Evo 9 Swap Into Evo 8 (NO SPARK)??
Old Mar 25, 2011 | 06:11 AM
  #31
acidtonic's Avatar
Originally Posted by mifesto
i dont disagree with you one bit. evo community is one of the most technical group in ALL automotive forum. im simply stating the negative side of posting info such as posting a how-to bypass a security feature that can easily be searched by badies with google. theres two sides of every coin, bro.
I think the same knowledge can help us protect ourselves better as well.
If you want some security, why not change your init code so it's even more difficult for someone to swap a rom in with the immob disabled? As far as I know you still have to be able to flash the car to disable it. Sure there's an unlocker for cycling through the init codes, but even that is yet another step where you probably just made the thief move on to the next less protected Evo.
An interesting hack would be one that honks the horn whenever the ECU receives an incorrect init code. It would make brute forcing the init code rather loud.
Anyways I'm so back to the discussion
Old Mar 25, 2011 | 08:34 AM
  #32
Evokid03's Avatar
I checked today for the pump and once i switched the ignition on im getting a constant voltage in the wiring/ i can here the pump turning on.. I even check at the rail where gas was poring out.
I also swaped injectors and nothing
Old Mar 25, 2011 | 08:46 AM
  #33
boosted_EJ1's Avatar
Any Cels? If there is im sure it will point you in the right direction
Old Mar 25, 2011 | 09:18 AM
  #34
Evokid03's Avatar
im going to advance auto to borrow the scan tool since im cool with my friends.
Ill keep you guys posted
Old Mar 25, 2011 | 09:26 AM
  #35
stamlon's Avatar
are you getting fuel?
Old Mar 25, 2011 | 09:30 AM
  #36
xpehbam's Avatar
Try to have the keys from Evo9 ecu next to your regular evo8 key. Your problem sounds like immobilizer problem and it makes perfect sense since you switched ECU's
Old Mar 25, 2011 | 01:19 PM
  #37
Evokid03's Avatar
figured out the issue guys
I swapped the Crank Angle Sensor and Bam, instant start up
Old Mar 25, 2011 | 07:14 PM
  #38
sharkm87's Avatar
ha...this was said in post #2...
Old Mar 25, 2011 | 08:53 PM
  #39
Evokid03's Avatar
Yes but A i didnt have a replacement sensor and B its not a 2 sec job.
James Jam
Dec 23, 2016 11:55 AM
Grimgrak
Apr 28, 2015 01:49 PM
tsidrift1
19
Aug 29, 2014 08:13 PM
Tmosser
17
Mar 3, 2013 08:18 PM
bosco121
11
Jun 7, 2012 09:41 PM
