Evo 8 stalling
Old Apr 14, 2011 | 03:55 PM
UGOTBUSLINKD87's Avatar
Evo 8 stalling
i have a 2003 evo 8, sometimes when slowing down coming to a stop when you press the clutch in the car stalls, not very often just randomly. Ive noticed it more when i try backing up my driveway its on a little slope. It had a service engine light on once for MAF sensor i cleared the code and it hasnt came back. So i searched what i could on it and some ppl said it could be a SAFC causing it has this happened to anybody else
Old Apr 14, 2011 | 08:20 PM
Hb55047's Avatar
I had the same problem. Turned out the previous owner screwed the biss screw all the way in and broke it. There are a few threads with info on how to check it with evoscan and tactrix cable.
Old Apr 14, 2011 | 08:23 PM
aznxkaiser's Avatar
Does it usually happen when you're low on gas?
Old Apr 15, 2011 | 04:43 AM
Only time I've noticed my gas was when it did it yesterday and I was 3/4 full...did it again this morning and I noticed my afc controller had cut off then back on but the car didn't die it just sputtered radio and all still on. So ima check the connection to the afc.
Old Apr 15, 2011 | 04:16 PM
4g63Boostjunkie's Avatar
I have an SAFC on my 1g Talon and it would shut off for a second or two and the problem was where the power cord is soldered on the board, somehow it had come loose. I took it to work and opened it up and just ran the soldering iron acrossed and heated up the original solder and it is still holding 1 year later.
Old May 18, 2011 | 11:55 AM
ok so i removed my safc, had my car tuned and it still randomly will idle low and sometimes cut off when slowing down to a stop with the clutch pressed in any suggestions
Old May 18, 2011 | 12:41 PM
nodnarb416's Avatar
what kind of cams are you running? and do u have a bov?
Old May 18, 2011 | 05:18 PM
Jschlo4's Avatar
It might be your bov if its venting atmospherically(if youre running one). I had the same problem with mine. Get the IX wastegate, you'll be much happier.
Old May 18, 2011 | 08:02 PM
prs0303's Avatar
usually Vacuum related (vacuum leak, BOV venting to atmosphere on a MAF car) could also be the Throttle body sensors going bad (IAC, FIAV or ISC)
it's basically related to a quick rev and then letting off the throttle, the car is naturally gonna wanna stall when you close the thottle plate and if there isn't enough vacuum to keep it open the car is gonna stall.
I would check the BISS screw on the TB first, thats an easy check...
Old May 19, 2011 | 04:54 AM
ill check BISS screw asap, is there anyway to check and see if sensor is goin bad and i have stock cams and a evo 9 bov
gixxer1k
Oct 17, 2018 09:23 PM
MLucas13
Oct 23, 2015 06:31 PM
DSMxJB
Feb 15, 2013 09:36 AM
jonzie04
Nov 1, 2011 09:44 AM
alpix715
Aug 30, 2010 03:13 AM
