This is why you should run a catch can
Old May 10, 2011 | 07:35 AM
  #46
localtoys73's Avatar
Originally Posted by mrboost05
I just ordered mine from them last friday i also ordered there dip stick that has the -6 fitting welded in i plan on running the drain from the can back to that fitting ive never seen anything like that come out of my cans that looks pretty clean compared to what normally comes out of my cans so its gotta be E85 related i have a few wiring questions neonglh but ill pm you those.
wouldnt that allow whatever is blown into the can(the gunk) back into the engine oil?
I just ordered the same set up and they told me to do the same thing but it doesnt make much since to do this.
nevermind I read the posts below this one. I still dont want it going back into the engine I think that defeats the purpose of having a catch can.
Old May 10, 2011 | 07:54 AM
  #47
Ev0ikon's Avatar
My catch can does the same and I run 93octane plus 50/50 meth/water. The fluid also has a sweet alcohol smell and a thin layer of black oil on top.
Old May 10, 2011 | 08:16 AM
  #48
SPANKED's Avatar
So what can doesn't everyone prefer? STM, Saikou Michi, Moroso? And is it necessary to have a can for the intake or is the manifold the most important one?
Old May 10, 2011 | 09:09 AM
  #49
Roadrunr's Avatar
Originally Posted by Pegasus
Actually the system goes both ways. Are you still running or do you have a check valve?
I still need to hook something up for my valve cover to intake manifold side. I'm gonna try to get something setup this week.
Good info found in here:
http://www.dsmtuners.com/forums/arti...cv-system.html
Excellent article. I prefer the Buschur
https://secure.buschurracing.com/cat...oducts_id=1268
I feel that this is the best with it's return port to the oil pan doubling as another pressure relief under boost. Therefore you do not have to drain the tank. If you run the PCV line to the old pcv fitting on the intake manifold and T off of it to the top port on this catch can you still pull a vacuum on the valve cover and the catch can when not on boost. I use a Krank Vent
http://www.et-performance.com/index.html
directly off the manifold thus allowing the old pcv port on the valve cover to empty into the can when under boost. The can will only allow the moisture to be drawn into the combustion chamber which is harmless to your engine.
Don
Old May 10, 2011 | 09:48 AM
  #50
dastallion951's Avatar
i gotta say even though thats e85 ur runnin after a 100 miles that nuts man. Personally I have a cusco oil catch can routed from cam side port, and in 20,000 miles from install to first clean, mine was VERY little, like your picture with the cup mine went up maybe a 1/2" to an inch in that cup if that. Thats a lot of blowby built up man. I hope your cars runnin good.
Old May 10, 2011 | 09:55 AM
  #51
neonglh's Avatar
It's not blowby, it's moisture.
And yes, it runs a 10.635 on the stock turbo, so I would say she runs pretty well
Old May 10, 2011 | 10:22 AM
  #52
alright for sure then thats different, i was gonna say for blowby your oil is in pretty good color haha, and yea that time is pretty damn good for a stock turbo haha...
Old May 10, 2011 | 10:38 AM
  #53
badev0's Avatar
I should probably go check my catch can now, lol.
Old May 10, 2011 | 10:43 AM
  #54
06MREvo's Avatar
This is a good catch can thread for anyone interested...
https://www.evolutionm.net/forums/ev...re-issues.html
I am personally using the split DC3 catch can setup...one can for the front right valve cover fitting to the maf pipe and one on the PCV side to the intake manifold...I deleted my PCV valve and installed 2 check valves. I also removed the front right fitting and had it drilled out for a much larger fitting. I have about 1200 miles on the car since it has been running again and have yet to drain the catch cans, Ill probably wait to drain them when I change the oil. I have to say the car seems to drive smoother since installing this setup...
Old May 10, 2011 | 11:03 AM
  #55
SPANKED's Avatar
Don
Thanks Don for the info but what I don't like about buschur's can is that it recirculates the waste back into the pan... I'm just learning about the PCV but that doesn't seem good adding the spent gas, water, hydrocarbons etc. back into the oil. The DSM article also mentions that it's bad to dump it back into the pan.
Old May 10, 2011 | 11:14 AM
  #56
SmurfZilla's Avatar
THis is the route I'm going but instead of the Split DC3 I decided to buy 2 seperate cans and run them similar to tscompusa's setup. Probably mount one on the firewall and on on the drivers side. With a line going to the bottom of the car.
Old May 10, 2011 | 11:30 AM
  #57
06MREvo's Avatar
When I said split catch cans I meant 2 seperate cans...
Old May 10, 2011 | 11:34 AM
  #58
mrboost05's Avatar
it does not hurt your motor in any way if it runs back to the pan the big internet rumor is it brakes your oil down so people have sent it out to get tested and the results were that we are not in the 60s oil technology has came along way since then not to mention most of us change our oil at 3000 miles or before think about all the hundreds of thousands cars on the road that dont have evap cans and egr systems have you ever seen a mom empty out here catch can in her mini van the dsm article is a great read i think the catch can thing is just going to be another one of those motorsports mysterys just like the proper way to break in a motor every car is diffrent tho ive seen this debate go on in just about every fourm do what makes you feel comfy but look at all the evos on the fourms that are stock block top to bottom with no catch can at all.
Old May 10, 2011 | 11:38 AM
  #59
David Buschur's Avatar
Originally Posted by neonglh
And mine:
Man that engine bay gives me wood.
Old May 10, 2011 | 11:40 AM
  #60
I read the first page only, I see on this last page our can was talked about. If anyone is interested in our can and they don't want it to drain back to the pan just ask. We can install a petcock on the bottom instead and you can drain it when you feel it need drained. We can also install -6 fittings on it to match the STM -6 fittings they offer for the valve cover, we carry theirs here too.
