Car Stalling when downshift
Old Jun 6, 2011 | 07:22 AM
acottin's Avatar
Every now and then my car decides to stall or almost stall when I downshift from 3rd to 2nd while slowing down to make a turn. I notice my RPMs dipping below ~500 when it does it. It also happens sometimes when I put the clutch in right before a full stop.
This only seems to happen during the summer and it gets worse on really hot days. It was slighlty corrected with some modification on my tune but it is still there. I was reccomended a boost leak check. Any other ideas?
My mods include 272? cams (not sure which cams since they were already installed in the car),intake, headers, dp with hfc, exhaust, mbc @ 23psi, aps bov
Thanks for your help.
Old Jun 6, 2011 | 07:24 AM
L@Ncer06's Avatar
is the idle high?
Old Jun 6, 2011 | 07:28 AM
acottin's Avatar
No. it normally idles between 800-1k. I actually have a few instances where I've seen it too low. I assumed it was because of the cams.
Originally Posted by L@Ncer06
is the idle high?
Old Jun 6, 2011 | 08:51 AM
thepoint4life23's Avatar
Maybe have someone check out the tune
Old Jun 6, 2011 | 11:38 AM
Jschlo4's Avatar
is the BOV recirculated or is it venting to the atmosphere?
Old Jun 6, 2011 | 11:42 AM
Iowa999's Avatar
That usually causes more grief on up-shifts, but it would still be useful info.
To be honest - and maybe this comes from my years with a DSM - the first thing I thought of when I saw "stalling when downshifting, especially when turning" is crank-walk. But to even say that term is to jinx the OP, so let's pretend that I didn't.
Old Jun 6, 2011 | 11:58 AM
Jschlo4's Avatar
I was under the impression that a VTA BOV will cause an sporadic idle and bog the engine if its ran with a MAF, especially after boost and coming to a stop. I had issues with my VTA when I would downshift before a turn. I got the IX DV and have not had a problem since.
Old Jun 6, 2011 | 12:46 PM
tuddy's Avatar
Had the same problem it was my IAC sensor. search for that, plenty of people have had issues with that sensor and then luck with replacing it.
Old Jun 6, 2011 | 01:59 PM
acottin's Avatar
It started doing it with the stock 9 BOV before and replaced it thinking it was going bad with dual port APS. I had the APS on my 8 before w/o any incident.
Old Jun 7, 2011 | 09:02 PM
red03evo's Avatar
check with your tuner. Maybe they can help you out. I thought it fixed already.
Old Jun 10, 2011 | 12:30 PM
dat*niz's Avatar
same **** here! had a turbo xs and before coming to a red light it will dip low and almsost shut off,installed a evo 9 metal valve and prob went away..
Old Jun 10, 2011 | 06:12 PM
d613's Avatar
hmm...this happened to me in my old car as well....it was actually the tune, needed a little bit of an adjustment.
Shinn
Jul 27, 2015 07:17 PM
whotippedmycow
May 28, 2014 12:47 PM
josephcastelar
Apr 22, 2013 11:37 AM
chickenbrest
Jan 24, 2006 06:26 PM
LancerEVOmann
15
May 4, 2005 02:31 PM
