car wont start after rebuild.
Old Jun 7, 2011 | 08:06 PM
awddyno's Avatar
Take the head back off and check it out.
Old Jun 8, 2011 | 06:35 PM
EVO8STI's Avatar
already did last night. found nothing suspicious. i think im gonna get a new gasket and try it again.
Old Jun 8, 2011 | 09:08 PM
1UpMoto's Avatar
are you sure the gasket was on correctly?
Old Jun 10, 2011 | 09:38 AM
EVO8STI's Avatar
yes. it can only go on one way. i thought maybe i was stupid too so i tried it all ways possible and only one way lines up. so yes its on correct.
Old Jun 10, 2011 | 09:48 AM
05blue8's Avatar
And you torqued it down in the correct sequence incrementally?
Old Jun 10, 2011 | 02:25 PM
EVO8STI's Avatar
yes sure did 20 50 80 worked my way inside out
Old Jun 11, 2011 | 12:52 PM
red03evo's Avatar
good luck
Old Jun 11, 2011 | 01:00 PM
erald01's Avatar
let us know how it goes second time around
Old Jun 11, 2011 | 01:28 PM
wht95scort's Avatar
Lets think about this...You said your oem engine blew? So did you get a used engine and put your old head on it or got a used long block with a head? Coolant can only get into the CC a few ways. Cracked bores( which I doubt it is as you say its all cyl) Cracked head again may not effect all cyl. Warpped head or block. This is most likely your problem. Check both surfaces with a straight edge. A real straight edge not a old metal ruler.
Old Jun 11, 2011 | 04:35 PM
billyblonco's Avatar
A you reusing the old head studs or new?
Old Jun 12, 2011 | 03:58 PM
EVO8STI's Avatar
its the old block with a used head. and yes i bought arp head studs.. im banking that there was something wrong with my head gasket. im gonna bring my head to a shop to make sure it is straight.
Dstorm7
Lancer Troubleshooting
15
Jan 8, 2018 04:32 PM
Don Q
Feb 2, 2011 06:11 PM
MitsuJoe
Nov 25, 2009 02:54 PM
xcelr8
Aug 25, 2009 07:30 PM
SuperBoostGuy
Jan 11, 2007 06:31 PM
