Need your knowledge, help me out.
Old Jun 13, 2011 | 04:59 PM
HN7's Avatar
HN7
Need your knowledge, help me out. (MAP sensor)
My car has been stalling when the RPM drop below 1500 and won't idle in N or any gears with the clutch so I decided to clean the Idle Sensor, Maf and whatever sensor I can find. The problem has stopped. However I found this sensor (I think it's the MAP sensor ) and there's 3 wires that's been cut and not connected to anything. Is this normal? Any help would be appreciated
Also, when I take it to a local shop, the mechanic says the pictured sensor went bad and is the culprit to my stalling problem. What do you think? Just want a second opinion before I spend $200 to get that fixed.
Attached Thumbnails Need your knowledge, help me out.-img_0177.jpg   Need your knowledge, help me out.-img_0179.jpg
Old Jun 13, 2011 | 05:02 PM
Vivid Racing's Avatar
Wow you have a lot of rust in there!!!
Yeah that looks like your MAP sensor. Not sure why it has cut wires?!?!? There should only be 3 wires to that sensor... I 99.99999%believe.
Old Jun 13, 2011 | 05:10 PM
HN7's Avatar
HN7
I know it's dirty in there lol. I just bought the car a month ago and just now got done cleaning the outside of the car, engine bay is next
Old Jun 14, 2011 | 06:23 PM
HN7's Avatar
HN7
bump
Old Jun 14, 2011 | 07:15 PM
Raptord's Avatar
Yes it's your MAP sensor, no the wires shouldn't be cut, and yes it could be the cause of your idle problems. While you're at it, may as well upgrade to a 3+ bar sensor
Old Aug 5, 2011 | 07:41 PM
drb's Avatar
drb
That is the map sensor but there are only supposed to be three wires going to it, yellow, gray & black. It looks like these wires are connected ok. What the cut wires (black, green & red) are for I don't know. I'm guessing that a previous owner had a different type of map sensor installed and those wires went to that, maybe?
Old Aug 5, 2011 | 08:05 PM
HN7's Avatar
HN7
I taped up those wires, clean out all the sensors and the IAC. The problem is fixed.
Old Aug 6, 2011 | 06:22 AM
mithrandir7533's Avatar
Did you check if those wires were spliced into the 3 wires for the map or if those 3 wires were running somewhere else?
Do a search on the IAC, you may want to replace or update it with a newer version as the 03 will eventually fail completely. Mitsu redesigned the IAC for the 2005+
SunnyC
Apr 14, 2020 05:21 PM
need_an_evo
Mar 29, 2016 09:14 AM
need_an_evo
Mar 28, 2016 02:21 PM
Spencer2362
Jun 25, 2015 11:55 AM
duranvw
15
May 31, 2012 06:41 AM
