buschur inline mbc install how to?
Old Jul 26, 2011 | 05:16 PM
taylorgang's Avatar
So I've been staring at this mbc for a good hour and still can't figure out how to install it... I cut off the vacuum tubes that went to my stock boost solenoid and found some metal wire in one of them... did i **** up? I'm so lost... I just changed the fuel pump to a walbro and that was easy as hell... now I get to this...
SOMEONE HELP ME
DAVID BUSCHURRRRRRRRRRRRRRRR helpppp
Old Jul 26, 2011 | 05:24 PM
forc3 f3d's Avatar
There are plenty of how to's on an MBC install. Just search for it.
Old Jul 26, 2011 | 05:30 PM
BlackOpsEvo's Avatar
Registered User
Can you post links?
Old Jul 26, 2011 | 05:36 PM
taylorgang's Avatar
dude, are you serious? I asked for HELP, not for you to try to up your post count...
I've searched the forums a bunch and it looks like installing an inline mbc is different than the other mbcs
https://www.evolutionm.net/forums/ev...procedure.html
http://highboostforum.com/forum/show...t-Installation
https://www.evolutionm.net/forums/ev...-needed-3.html
http://www.genesisowners.com/hyundai...ead.php?t=2516
https://www.evolutionm.net/forums/ev...c-install.html
I've searched through all those threads and can't figure it out...
Old Jul 26, 2011 | 06:09 PM
evo8426's Avatar
This is directly from Buschur...
http://highboostforum.com/forum/show...314#post137314
Old Jul 26, 2011 | 06:13 PM
taylorgang's Avatar
Originally Posted by evo8426
I read that a few hours ago and I've looked at it a lot... it's not much of a "how to"... more of a "oh this is how our mbc works, figure out the rest"
for now this is what I figured I'm going to do :
take br supplied vacuum line, cut in half, connect vacuum line to wastegate nipple, connect to mbc. then connect vacuum line from turbo outlet pipe (which was originally T'd to the wastegate and the boost solenoid) and connect that to the MBC... sound about right? I just need to figure out if I need to cap off the vacuum line that runs from the intake
Old Jul 26, 2011 | 06:17 PM
VRSF Tiago's Avatar
Give em a call in the morning
sparky's Avatar
Cool link, evo8426
Old Jul 26, 2011 | 06:19 PM
evo8426's Avatar
Well it tells how to install it. I'm not sure what you're not understanding about it. There is a line that runs to the nipple from the turbo which goes on the "IN" side and then there is a hose that runs from the "OUT" side that goes to the wastegate nipple. You cap off where it would go on the intake and you cap off the 2 barbs that are on the stock BCS.
Old Jul 26, 2011 | 06:23 PM
sparky's Avatar
Originally Posted by taylorgang
..... I just need to figure out if I need to cap off the vacuum line that runs from the intake....
I've always capped that intake hose nipple off when installing an ordinary, garden variety, MBC. It must be the same with this Buschur unit, I'd think.
Old Jul 26, 2011 | 06:25 PM
taylorgang's Avatar
well do I need to remove the stock intake pipe and all that stuff to install it? I'm trying to install it from under the car and it seems like a daunting task...
Old Jul 26, 2011 | 06:26 PM
taylorgang's Avatar
Probably what I'm going to end up doing
VRSF to the rescue...
Thanks Tiago haha
Old Jul 26, 2011 | 06:34 PM
sparky's Avatar
You remove the complete factory boost/vacuum hose assembly. There is no need to cap off the fittings on the BCS. However, do leave the electrical connector pugged into the BCS.
Plug the nipple on the MAF(intake) by cutting off a 2" length of 4mm rubber hose and putting a tight fitting 1" long machine bolt into one end of the piece of hose and securing it with a 1/4" hose clamp on each end onto the nipple. This is just like the pic on the Buschur site for installing their oil catchcan BTW.
Old Jul 26, 2011 | 06:36 PM
sparky's Avatar
Install from above. It is pretty simple.
Old Jul 26, 2011 | 08:31 PM
Teal2nnr's Avatar
http://www.gencoupe.com/2-0t/13207-b...tructions.html
This is for a genisis, but it applies.....Its only 2 lines...not hard.
