P0300
Old Sep 16, 2011 | 08:02 PM
barneyb's Avatar
There are (or were) two oxygen sensors. The code tells you which one.
Old Sep 19, 2011 | 03:53 PM
ryanholder24's Avatar
i think my o2 sensor is the reason it gets hot every now and then but goes right back down
Old Sep 19, 2011 | 06:14 PM
barneyb's Avatar
The O2 sensor is used for closed loop meaning the ECU adjusts fuel based on whether there is oxygen or not in the exhaust. If the O2 sensor fails then the ECU does not go into closed loop and runs off of a fuel map stored in the ECU memory. Unless the tune is bad this shouldn't make the engine heat.
I suggest checking the thermostat and fans. Also keep an eye on the overflow jug becasue this could be a head gasket problem.
Old Sep 20, 2011 | 02:57 PM
alright it just started doing it like once a week but the random missfire has been their a while
dxlykos0131
May 7, 2014 06:15 AM
Poondoggs
Nov 6, 2009 09:19 AM
djulian21@juno.
Feb 9, 2008 07:16 PM
MYFIRSTEVO
12
Oct 18, 2005 05:12 PM
